I have never machined much plastic before and now have a job that will require all .062 and .031 dia mills which I am not used to using. The part is only .089 thick and is basicly just a square type cut out with a boss on one side all corners have a .015 radius. My question is what to start speeds and feeds at. Machine is mini mill 6k spindle I have carbide 2 and 4 flute mills I am thinking that the 2 flute tools will be the way to go. Thanks Mike |
| Sorry I missed the .031 and .062 .031 Number of Flutes: 2 Revolutions per Minute: 6000 Feedrate: 9.5 IPM Axial Depth per Pass: .016 Radial Width of Cut: .031 Power Requirement: N/A .0625 Number of Flutes: 2 Revolutions per Minute: 6000 Feedrate: 19.2 IPM Axial Depth per Pass: 0.031 Radial Width of Cut: 0.062 Power Requirement: N/A As for drilling get a 135* split point screw machine drill. MC |
| Yes, Granted I don’t ever run plastic but one of the calculators I have does have a wide Varity of plastic. Seeing no one answered his question I figured I would help the best I could. I plugged in his machine specs max rpm and material. It should get him close tweaking may be required. MC |
#10
| Some of our parts are plastic. Delrin, Tecapro, and rydel. We like HSS for the finish passes when possible. Lower RPMs than if cutting aluminum (plastic likes to melt). Conventional milling instead of climb makes better finish on walls. Plenty of coolant to flush. Deburr completely on the machine (using spot drill to break all possible edges). Onsrud makes some plastic cutting tools that work well too. (Don't work for them, just bought 4-6 tools) |
#11
| I have never used a machining calculator do they get you pretty close. Are they on the conservative side or the max it will do entill failure. Do they tell you basic power needed and does this ussually come in close. Finally what one would you recommend and how much does it cost. Thank You Mike |
#12
| Need Help!- machining plastic | mmiranda | General Metalwork Discussion | 8 | 07-04-2009 10:42 AM |
| Milling Black plastic blocks | joguy | Machinist Feedback | 6 | 11-20-2008 12:57 PM |
| Machining Plastic (Centriboard) what bit to use? | abelloise | Glass, Plastic and Stone | 1 | 07-08-2007 11:01 PM |
| Machining Plastic (HDPE) | Buzz9075 | Glass, Plastic and Stone | 11 | 07-01-2007 06:45 PM |
| Machining engineered plastic | skykash2000 | Test Forum | 0 | 09-18-2005 08:34 AM |
