I've been rigid tapping 10-24s a bunch on my super mini mill 2 in aluminum. That works flawlessly. I don't know about larger sizes.
Hi I have a 2002 mini mill 6k spindle machine I want to add rigid tapping to it but would like to know what the machine is capable of.
Meaning is this machine limited to very small holes because of its power
1/4 20's of can you do 1/2 13's when using the peck tapping this would be
in alum material.
Also will it tap steel and stainless mabey up to 1/4 or3/8 theads.
I want to tap in a er collet like I do on my vf-3 I am assuming this is possible on the mini mill also.
Thankyou my spending is limited This is only a part time thing for me and do not want to waste $1200.
Thankyou any help would be appreciated Mike
Thank you Gabe for your response.
I need it to do at least a 3/8 thread and would like to know if people are doing this with this machine.
Thanks Mike
Why haven't you just turned it on for the 200 hour trial period and tried it?
The 200 hr trial will work for the software, but make sure you have the encoder on the spindle.
With that said....I have a TM-2 with the same spindle as a mini-mill. I do 1/2" tapping all day into 6061 and it gets a spindle load of about 60%. I have done 3/8 in SS but did not note the spindle load. I use Kennametal tap collets which seem to work really great.
My machine is a 2002 Can I still get the 200 hr trial I did not think they went back that far.
Thanks Mike
Go in your parameters and look for rigid tapping. If it is in there exit out and hit the estop. Then go back and change the 0 to T.
Tim
Haas told me the the previous owner already used this optionwell that figures)
thanks anyway Mike
I tapped m10x1.5 today in CRS today without a problem. I have repeat rigid tap turned on, and I peck rigid tap all my holes.
If you don't want to buy the option, invest in a Floating holder. They work.
As far as tapping, our all our Haas do small tapping, under 3/8 in this shop.
But I think the Minis are 7hp, and we had a couple Kia's back in the day that were rated for 7hp and no rigged tapping, just floating.
Well we were tapping 3/4 taps in 304SS. It loaded out the machines, but 2 machines would do it and 2 wouldn't. I guess the other two where just more tired....
Mike in MN
http://www.cncbasics.com
http://www.cncbasicsforum.com
http://www.mastercamforum.com
http://www.mastercamblog.com
www.cncbasics.com www.mastercamforum.com
But by the time I buy at least 2 of these floating holders and the collets for them I will probably be close to the price of just buying the option.
Thanks Mike
