Old 10-15-2009, 09:15 PM
TravisR100 is on a distinguished road
Chip load/feed per tooth calculation
I must be figuring this wrong or I'm not understanding something correctly. On my Haas mill I'm using a 5 insert 2.5" face mill runnig at 755 RPM at 19 IPM. What does the chip load come out to? The Haas is reporting the chip load at .0126. Wouldn't this be a chip load of .0032? Or is the feed rate the Haas reports not in IPM?
Old 10-15-2009, 09:25 PM
mls mls is offline
mls is on a distinguished road
It looks like your tool is set to 2 flutes in the haas control
Old 10-15-2009, 09:32 PM
mls mls is offline
I think your chip load is more like .005 per tooth
rpm x feed per tooth = feed
755 x .025 (.005 x 5 teeth) = 18.75 inch per minute
Hope this helps Mike
Old 10-15-2009, 09:33 PM
King bob is on a distinguished road
Have you inputed tool information in the of set page? If not you might be
getting skewed info from an old setting/offset.
Old 10-15-2009, 09:35 PM
I've already powered down the machine for the night but I'll go back and check that. Now that you mention it it's definitely possible that I missed setting the correct number of flutes when I set the tools up for this job. Thanks.
I knew I had to be missing something somewhere. Those numbers just didn't make sense.
Old 10-16-2009, 12:17 AM
rawen2 is on a distinguished road
I also come up with .005" per tooth chip load.
19"/755 rpm = .025165" per revolution.
.025165"/5 teeth = .005033" per tooth.
Ralph
Old 10-16-2009, 12:53 AM
peter.blais is on a distinguished road
Just to stick it into one equation
Feed = RPM * Chip load per tooth * number of teeth
If the haas control is not reporting the right schtuff, you don't have the right number of flutes in the tool offset page.
Gabe Newell is on a distinguished road
Me, three.
At .0032 per tooth, it's 12.080 IPM.
Old 10-16-2009, 07:25 PM
crabbass is on a distinguished road
for what it's worth,
I leave all of the flute # set to 1 in the offset page. When the machine is running you can easily divide the number on the control by the number of flutes the tool being used has in your head, or use a calculator if you want an exact figure.
For long run jobs, If I was an operator that was bored, I would probably set the tool type in the IPS to match(drill, e-mill, etc.), the flutes, and all. But for quick change out jobs, and wanting to input the minimal information into the control, this is what I have found to work best for me.
Old 10-16-2009, 10:01 PM
Crab, that's a great idea actually. I'll go reset them all to 1. Obviously I forget to enter the correct number of flutes when setting up tools.
  #11   Ban this user!
Old 07-21-2010, 01:32 PM
15mgtar is on a distinguished road
excuse my ignorance but where do I get the "Chip load per tooth" data for metric endmills? (I'm doing wood)
Chip load & speed /feed info ynnek DIY-CNC Router Table Machines 0 03-09-2009 08:44 PM
Where to buy 24/32 TPI straight-tooth set 131-1/2" Blade? + Q on wavy tooth sets mcm375 General Metal Working Machines 2 11-25-2008 09:28 PM
Chip load and cutting depth. SCCoupe DIY-CNC Router Table Machines 3 07-19-2006 02:24 PM
chip load question cncsdr General Metal Working Machines 1 10-11-2004 08:08 AM
