I have a 2002 mini mill (standard 6k spindle). I am running it single phase my haas dealer told me it makes no more power on three phase with the way haas wires it I think something with the spindle drive. I do have the medium size phase perfect converter but see no reason to use it unless it will make more power. Anyway what is your opinion on that. Also I would like to buy the rigid tapping option will this tap a 1/2 -13 thread in alum .65 deep and what size is safe in alum / steel / stainless. I have heard of pecktapping on the haas does this work very good The tapping option is kinda exspensive (but so is handtapping) I just dont want to be limited to 1/4 - 20 threads Thanks for your help Mike |
| Mike, We have a 2000 Mini Mill (6000k spindle) & I used to rigid tap M16x2 holes in 65-45-12 Ductile Iron with no problems (full depth @ 3/4" deep). The reason I don't use the Mini Mill to do it now is because we have a VF4 APC & we can do a lot more of these parts on it. I also tapped M20 holes, but I only started the threads in these holes maybe 1/4" deep (same material as above). I did tap 1/2 -13 holes in steel a lot as well, but I used spirial fluted taps when I did this. I would recommend the rigid tap option for sure. The MM can handle it. We used our MM on A36 Steel, A572 grade 50, 4140, 1018, 304SS, A360 Brass & 6061. This little machine is a real workhorse. We only run single phase on it, but we do have 3 phase power coming into the shop for the other machines. Hope this information will help you out. Greg |
| Mike, We always use single depth tapping. I heard of people peck tapping & I have wanted to try it, but just never got around to it. For sure you will be able to tap larger then 1/4" holes. The mini mills are good little work beasts. I have even used a 3.5" 60 deg inserted dovetail cutter (in A36 & 4140 steel) on it (multiple steps) and with no problems. Glad to help. Greg |
| tapping on a mini mill without rigid tapping??? | mls | Haas Mills | 13 | 07-03-2009 06:43 PM |
| rigid tapping on mini-mill | plastibob | Haas Mills | 3 | 01-05-2009 04:29 PM |
| What exactly is Rigid tapping? Why people always ask does it do rigid tapping? | cjchands | General Metalwork Discussion | 23 | 12-19-2008 08:19 AM |
| Rigid tapping on Haas Mini Mill | rrossey | Haas Mills | 16 | 03-15-2008 09:29 PM |
| Mini Mill can it repeat rigid tap? | Loading | Haas Mills | 7 | 09-11-2007 09:26 PM |
