| We are thread rolling an alum extrusion 2-56 (kinda gummy characteristics) 6063 maybe not real sure. Question 1: Does any one have any info on how the threads are supposed to look? The recomended size is .078-.080. we went with .0765 roughly. the threads still look like they have 2 crests, top and bottom. Question 2: Is this typical for thread roller taps? Any info on this matter would be greatly appreciated. nfs |
| The threads will look like threads with out burrs. I get a reccomended drill size of 5/64 or .0781, your .0015 smaller and in all honestly that may make a difference in a 2-56. but I doubt it. Its not typical as what you describe. does the hole your drilling have a nice finish? if the finish looks bad in the drilled hole then so will the thread on the minor. are you sure you have the proper lead programmed in (feed rate) if your off on a small thread like this it will make a huge difference. Delw sticky material on small threads make sure you use good strong coolant |
| Thanks for the help, this mat'l is real gummy, we went with a .075 drill and the threads look better now. thanks for the help. we also slowed the feed down on the drill from 10. ipm to 5 ipm seemed to help stabilize the hole size.(side note: tried .074 drill in 6061 then tap and tap broke immediately |
| Tags |
| threading |
| roll form tap better in 316 stainless? | stovepipesteve | Haas Mills | 1 | 08-05-2008 06:26 AM |
| Need Help!- Roll tapping. | Mitsui Seiki | G-Code Programing | 2 | 06-16-2008 11:37 PM |
| On A Roll - Another new machine | vacpress | DIY-CNC Router Table Machines | 6 | 10-31-2007 10:17 AM |
| Help with selector switch wiring issue (***actually a motor issue***) | BEDFORD | Industrial Hobbies (Support forum) | 7 | 04-07-2006 03:19 PM |
| Simple question: Hot roll vs cold roll steel | CuttersCov | General Metalwork Discussion | 1 | 02-16-2006 07:38 PM |
