Old 09-25-2009, 02:40 PM
anemachinebc is on a distinguished road
Broken ball screw
We had a ball screw snap off at the coupler between the servo motor and the screw itself. Has anyone had this happen to them before? This machine wasnt crashed, it just broke while it was running a program.
I just love HAAS machines.
Adam
If HAAS made a plane would you fly in it?
Old 09-25-2009, 06:06 PM
Do you have pictures of the broken ends? My guess is that this would be a fatigue fracture and I am interested to see what the initiation point was for the crack.
Old 09-26-2009, 08:01 AM
samhyto is on a distinguished road
Wow, like geof siad, would love to see pictures of the crack? Sounds like it was just a defective ball screw?
But.....there could be some other underlying issues.
Which axis, since the Z is always doing alot of changes of inertia, and there is alot of mass in the head?
Is it a SS machine, these have faster pitch screws?
Has the operator noticed higher than usual loads on the effected axis recently?
How old is the machine as well?
Sam
Old 09-26-2009, 09:39 AM
asuratman is on a distinguished road
It happened to me also, it's broken inside the coupling. I made beveled cut on ballscrew and bar. Re-welded and machined. It works OK. But I do not know how strong. Maybe you just try, better than you throw it. If it broken in the screw, just cut and machine. The, use it for another purpose. Thanks.
Broken Tap / Screw Removal zcases General Material Machining Solutions 12 10-31-2011 10:45 AM
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
