Results 1 to 6 of 6
Thread: TL-1 door open alarm won't go off!
    Sep 2009
    No matter what I do for whatever reason the door open alarm won't go off on our TL-1. Any ideas?
    Jul 2005
    The proximity detector may have a small chip sticking to it. It is on top of the headstock near the back where the shaft for the chuck guard is. When the guard is open a small metal tab comes down in front of the detector. (I think, I may have it backwards.)
    Sep 2009
    When its open the chuck guard gets closer to it. Still about an 1/8 inch gap from touching it. Then when you lower the chuck guard there is a notched section that makes the gap closer to 3/8 of an inch. Is that right?
    Jul 2005
    I think so, is the end of the proximity detector clean? Any chips on it give the same effect as the when the guard is open.
    If that is clean are you pushing the little hand button thing that you are supposed to hold all the time for the machine to run?
    Sep 2009
    I wasn't pushing the hand button!!!! Ugh.....I can't believe I fought that thing for that long and forgot the button! Thats what 12hr shifts does for you!
    Jul 2005
    Quote Originally Posted by donsbad89 View Post
    I agree, take some time off.
    1. Need Help!- OKK G4 tool change door open
      By dannystooblue in forum OKK
      Last Post: 09-18-2009, 09:26 AM
    2. Charmilles Robofil 300/310 Door Alarm
      By WIRE CUTTER in forum General Waterjet
      Last Post: 07-25-2009, 07:34 PM
    3. kira vtc30a door won't open
      By nevron in forum General Metal Working Machines
      Last Post: 11-28-2008, 09:30 AM
    4. shutting down door alarm for mazak t plus
      By scott 54 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 12-13-2006, 08:27 PM
    5. Mini Mill door open alarm
      By paptep in forum Haas Mills
      Last Post: 11-21-2005, 04:31 PM
