Old 09-22-2009, 09:58 PM
JasonR is on a distinguished road
Renishaw TS27R tool setter on HAAS machine.
Anybody using one of these? We have one that came on a Mini-Mill we purchased but have not messed with it. Are the worth the trouble to setup?
Jason
Old 09-23-2009, 12:05 AM
crabbass is on a distinguished road
Once you go probe, you won't go back.
Do you like manually touching off your tools? Or would you rather just push a few buttons? In process length varification and other uses as well.
For Instance...
If you have a small center drill that you have problems breaking, so you stand at the machine to make sure it does fine, so the drill doesn't get smoked when it starts.
with a tool probe, you could measure the center drill after it finishes, If it is broken the length will change and generate an alarm, If it is within your alarm limits Your cycle can continue on uninterupted (and unattended).
Old 09-23-2009, 01:36 AM
Matt@RFR is on a distinguished road
Jason, do a search here and all your questions will be answered.
EC1600 - Renishaw TS27r Ginger_Ninja54 Haas Mills 4 02-26-2009 01:05 PM
Newbie- Protection for Renishaw Tool Setter Gus-Gus Haas Mills 3 12-05-2008 09:35 PM
OTS Renishaw Tool setter help, Actually using it? mgb1974 Haas Mills 20 06-02-2008 08:54 AM
OTS Renishaw Tool setter help mgb1974 Haas Mills 6 03-18-2008 06:19 AM
Renishaw Tool Setter Mounting Position HelicopterJohn Haas Mills 21 01-05-2008 08:17 PM
