I am trying to setup comunication between my laptop and a control on my buddies VF-2. I am using a purchased usb cable with a 9 pin male connecter on the other end. I made up an rs232 cable (9 pin to db25) to the specs in the haas manual. It connects to the usb cable and goes to the machine. Drivers were loaded for the usb cable. Using predator software I am able to send files to my laptop but the problem is sending programs to the machine. The machine will just stay in the recieving mode. The confiusing part is that in the attempts to upload, every once in a while it will suddenly work and send the program up the instant I close the predator side of the communications down. settings on predator are: 9600,even 7 ,1 haas are: 9600,even,7,1 Could the cable be the problem (bad solder on the send wire)? Any ideas? Thanks caddisfly |
| When you send programs to the Haas machine you should start and end with a %. I chased this for a few days before I figured it out . I use Bobcad and at the bottom of the send window it asks you the start and end blocks. Yours may have something similar. BL |
I had a lot of trouble when setting my new laptop and new cad/cam but was lucky that i bought the usb to 9 pin from cad/cam company so i let them work it out, it turned out to be the driver for the usb to 9 pin that was at fault once i had the latest driver worked first time. |
| Need Help!- Computer to Control Comunication problem | JAnderson | Okuma | 4 | 05-21-2009 01:55 PM |
| Need Help!- Comunication problem VTC-41 | Jcip | Mazak, Mitsubishi, Mazatrol | 1 | 03-20-2009 04:49 PM |
| Need Help!- Can't Send From Control To Laptop | metx | Fanuc | 16 | 05-04-2008 10:04 PM |
| Fagor RS-232-comunication. | GPena | Fagor Automation | 1 | 12-21-2007 07:22 PM |
| mitsubishi comunication | rosli | Servo Motors and Drives | 3 | 05-27-2006 04:14 PM |
