Old 09-04-2009, 12:08 AM
crabbass is on a distinguished road
RS-232 output
I have an 08 VF-3, pretty standard, with renishaw probe. I would like to write a probing cycle to use the machine as a CMM. The accuracies I am looking for are pretty easy to obtain +.00/-.01 on a verry complex form. When I say +.00/-.01 I am reffering to the shapes acceptable profile limits. What I'd like to do (but don't know how) is to output the probed coordinates into a spread sheet, or .txt file. I can present an excell spreadsheat with columns of "perfect model" numbers, and the probed parts actual numbers to non mechanical management types without too many difficulties . If my part has 50 points that need probed, I would like a list to be output with x,y,z,a coordinates relative to the work offset.
I don't have the ethernet option.
Any suggestions would be much appreciated.
Old 09-04-2009, 12:20 AM
pit202 is on a distinguished road
if you do a probe cycle eg X+ :
G65 P9811 X...
you can add W1 or W2 at the end of line and get some parameters , if this is too much for you , you can write after that line :
DPRNT[X#185[44]*Y#186[44]]
and get only actual X and Y parameters
Peter
Old 10-11-2009, 07:02 PM
Integrexman is on a distinguished road
I do what you are trying to do all the time. I have a Renishaw MP700 probe and the InspectionPlus macros. I am able to ouput XYZIJK (point and vector) data from my CAM system. I made a program that I can input the data and it creates a probing program that uses macros 9810 9821 and 9811 to probe the part. I put a W1 on each line so it writes the data/report to my memory card as a text file. Here is a report example. It shows the target data, actual measurement, tolerence+/- and deviation from target.
COMPONENT NO 1 FEATURE NO 1
POSN X 2.7097 ACTUAL 2.7097 TOL TP .0050 DEV .0000
POSN Y- 2.8893 ACTUAL - 2.8910 TOL TP .0050 DEV - .0017
POSN Z- .7588 ACTUAL - .7574 TOL TP .0050 DEV .0014
Here is the code that was used to probe the point above:
G65P9810 X2.6989 Y-3.1802 F100.
G65P9810 Z-0.5224 F100.
G65P9821 X2.7097 Y-2.8893 Z-0.7588 C2 H0.0050 W1
Here is a link to the program and a video probing a part.
http://cncwrite.com/cmm.php
Best viewed with VLCMedia player.
http://integrexmachinist.com/Video/I.../ProbeFace.mpg
Output 2 fourwheeler Machines running Mach Software 1 07-24-2009 05:44 PM
no motor output eloid DIY-CNC Router Table Machines 3 06-15-2009 08:19 PM
Problem- I&J arc output instead of R zelaznog Post Processors for MC 6 06-15-2009 08:30 AM
output a D after the G41 or G42... shape Dolphin CADCAM 3 04-28-2009 02:04 PM
PSU with 2 different Output Voltages ? Joey General Electronics Discussion 4 06-09-2007 08:02 PM
