I am trying to tap about 20 holes in an aluminum part I am making out of 6061 T6. The hole is a through hole that is .25 deep. I am using a 95 Haas vf-2with ridged tapping. My problem is I am breaking taps on the first hole. I am using a spiral point 2-56 tap. It goes in about .2 and snaps off. I have never needed to tap something this small before. I have done tapping on this machine 1/4-20 and up just fine. Any suggestions? |
| Looks like good ole mastercams calculation is the issue.. can somebody check this for me?? From what I have been told. For rigid tapping you figure feed by RPM X thread pitch. It appears as if the tread pitch for a 2-56 thread is .0744. This would mean that if the RPM is set at 3109 then the feed should be 231.3096 and its set at 55.5233256 instead. So this is what I should be using....?? RPM 1000 Feed 74.4 Please if someone could check the thread pitch value is correct and the calculation that would really help me out to know if I am back on track before breaking another $20 tap in a $50 part on the last op. |
a roll tap will do a thread better than a cut tap on small alum threads. its very important to have the proper size drill for a roll tap and use good coolant. also make sure your holders are running true. |
| here this will help http://haascnc.com/training/MillProgram_PDF/xmwb.pdf |
| So 1 divided by 56 threads per inch equals .017857 This should be 1000 RPM x .017857 = Feed 17.857 The tap drill size is a 5/64 |
#10
Okay, I checked this two ways: 3109/56 and 3109*(1/56) and my Windows calculator comes up with 55.51785 unless Microsoft is wrong again this would be the feed rate for 3109 rpm.
#11
| for TPI I use --- 1"/ tpi *RPM= Ipm feedrate. I see this is how some of you calculate it also. The cam software I use (this may be an error with my postprocessor) will always generate a feed slightly faster than the above mentioned method. When I tap holes (not verry often) it is rigid tapping, as I don't have floating tap holders-drivers etc. The slightly faster speed I am talking about is verry slight, Like the post rounds to the .XX decimal when dividing the TPI. For example, I would have to tap a 1/4-20 like 10 inches deep to have the feed skip one lead. Do the people using floating tapping heads program with this feed slightly increased to "load" the spring? Again, I have written this off on a post processor error, and when I forget to edit the feed to the exact pitch, I havn't noticed any problems, I don't usually tap deeper than .6" on a 1/4"-20 |
| G84 Rigid tapping and more | Karl_T | CamSoft Products | 16 | 01-17-2012 07:38 PM |
| tapping on a mini mill without rigid tapping??? | mls | Haas Mills | 13 | 07-03-2009 06:43 PM |
| What exactly is Rigid tapping? Why people always ask does it do rigid tapping? | cjchands | General Metalwork Discussion | 23 | 12-19-2008 08:19 AM |
| Tapping head or rigid tapping | Gregory_C | Syil Products | 2 | 10-18-2008 12:49 AM |
| Rigid tapping or tapping head | wildcat | Industrial Hobbies (Support forum) | 7 | 09-24-2006 12:08 PM |
