Old 09-01-2009, 02:28 AM
Gabe Newell is on a distinguished road
Super Mini Mill 2 Buzzing from Air filter/regulator
I have a new Super Mini Mill 2 (less than a year old).
After I run for 3 or 4 hours, a buzzing sound starts to come from the bottom of the air filter/regulator. The buzzing gets progressively louder, and I have to shut the mill off for several hours to get it to stop.
If I put my finger under the bottom of the regulator, the air coming out feels moist. I don't have a dehumidifier (yet) on my air compressor.
Any ideas?
Old 09-01-2009, 06:02 AM
riverracer is on a distinguished road
is it the auto drain?
Old 09-01-2009, 06:59 AM
SORCHEROR is on a distinguished road
its the auto drain on the filter reg,maybe its dirty,my gets that way sometimes from dirty
gunky water that runs thru it,the clear bowl should twist off,turn off the air first,than clean
it all out and put back on,it that fails to work might have to replace the reg
Old 09-01-2009, 09:31 AM
Originally Posted by Gabe Newell View Post
...If I put my finger under the bottom of the regulator, the air coming out feels moist. I don't have a dehumidifier (yet) on my air compressor.
Any ideas?
It is the drain on the water trap doing its job. Carry on using wet air and you are headed for all the annoyance other people have described regarding sticky solenoid valves and tool changer malfunctions.
Old 09-01-2009, 04:43 PM
Thanks, all.
I will clean the bowl and also get a dehumidifier.
Super Mini Mill - decisions TravisR100 Haas Mills 39 09-01-2009 11:21 AM
HELP!! Haas Super Mini Mill CountBraden Haas Mills 4 07-06-2008 07:20 PM
HAAS Super Mini Mill Ford25 Haas Mills 13 09-07-2007 09:01 AM
help with super mini mill please daleman Haas Mills 12 08-14-2006 03:32 PM
part for super mini mill daleman Haas Mills 0 05-04-2006 02:03 PM
