Does anyone know of something I could replace the floppy drive with so I'd have more memory potential. Optimally, I'd like to use a USB stick and then DNC off of that. I know I can DNC from another computer and trickle feed, but I'd rather not have to do that. We have a VF zero and VF2 that are around 7 years old. Why do CNC machines have to be such a pain in the ass when it comes to memory. They should all come with a gazillion gigs of memory. My frickin phone has 32 gigs. Come on now. Thanks |
| John, Let us know how it works for you. I've wondered how the Haas would handle files that are bigger than should logically fit on a floppy drive, and whether you'd have to break them down or not.
Yes, that would be really nice if it would work with the older HAAS equipment with the 3.5 floppy drives. I would also be interested in feedback from anyone that tries it on HAAS equipment. I have recently looked at some older HAAS CNC lathes with the 3.5 floppy drives. I like the USB port on my 2007 HAAS TM-1P and this upgrade path would be nice if it works. John |
Got it installed today and to my surprise, it worked perfectly without ANY messing around. I loaded a program just like I would off a floppy, no problem. I also DNC'ed and it worked just like it should. I didn't get a chance to try DNC-ing a large file yet. I think it will work since the control works it's way through the code while only buffering a small portion. Just like using RS232 Thanks Hu! (Instruction on how to DNC from the floppy are in the manual.) |
| Its good to know it worked out okay.
#10
| When i read the instructions for that unit, it specifically said you cannot exceed 1.44mb for a folder to emulate as a floppy. If you can actually DNC from a larger than 1.44mb file, please post a reply! thanks! |
#11
| Still better than using retarded floppies. Way faster. JW |
#12
| I've had zero experience with doing the DNC on the Haas so I don't know what is legal and what isn't. But could you write sub program calls in a main program on the control and somehow have it jump to various folders on the floppy, supposing that each folder has 1.44 megs worth of a much larger program that you split up?
| Need Help!- DNC from floppy drive | jwknow | Haas Mills | 5 | 03-11-2010 09:39 AM |
| Floppy drive alternative | rbever36 | General CNC (Mill and Lathe) Control Software (NC) | 1 | 06-18-2009 07:46 PM |
| Haas TM-1 Floppy drive | speedrider | Haas Mills | 13 | 05-13-2009 01:45 PM |
| Floppy Drive | advt001 | Cincinnati CNC | 4 | 10-11-2008 10:35 PM |
| Has anyone tried a Floppy drive adapter ? | meadowtech | Controller & Computer Solutions | 1 | 04-18-2008 05:51 AM |
