| Command the following in MDI: M19; M19 P90.; M30 The spindle should rotate the drive lugs parallel to X axis, then if you have the "Option" it will rotate 90 degrees from that position. If you do not have the "Option" it will stay at the first position or "Not Available" will pop up on your screen. Loose Nut |
The 90 degree head has to be located by a pin in a block bolted to the end of the spindle housing. Spindle orientation has no effect on the position of the 90 degree head, but many of them can be adjusted to almost any angle relative to the X Y directions, only not under program control it has to be set and locked.
| Need Help!- Have no spindle orientation | plofkop | Okuma | 8 | 04-05-2010 04:47 AM |
| Need Help!- Spindle Orientation | JIMMY | General Metal Working Machines | 5 | 08-03-2008 12:15 PM |
| Spindle orientation | StampCraft | Haas Mills | 5 | 11-10-2007 06:31 PM |
| Spindle orientation | jimecv | Daewoo/Doosan | 4 | 11-09-2007 12:25 PM |
| 16i / 18i Spindle Orientation... | Sump Cleaner | Fanuc | 12 | 09-11-2007 08:46 AM |
