| spigot failure VF2 15 months old never had A problem.alarm 196 coolant spigot failure.It started last week couple times the programmable coolant kind of got lost kept going back up all the way towards the spindle.Now it wont even let me adjust with control.Is this something someone may say is an easy fix.Is there something maybe loose?Just going to have to replace the spigot box? Thanks Chris |
| PCOOL One of the guys here on the forums gave me an old spigot nozzle (PCOOL) that was doing the same thing. This was the older 20 position PCOOL nozzle. Another guy suggested that I take it apart and check the micro switch that rides on the cam. As it turns out the micro switch was missing some of the steps and caused the problem. I found a replacement micro switch at a local electronics store for around $2.00. I had to modify it a little but that fixed it and it has been working perfect ever since. There is a post either here or on PM that has the pictures to show what was done to fix it. I don't know if the newer PCOOL nozzles are different or not. But before you throw it away I would check it out. Let me know if I can be of further assistance. Just send me a PM with your phone number and a good time to call you and I will give you the details. John |
| Thanks John.I have 2 roller switches that both check out ok.I am going to pick them up from grainger and replace them for 7.00 doesnt hurt.The motor works.I manually bring the spigot down it brings it back home then its over,it does nothing after that.Change the switches and see what happens after that I will have to go deeper into the electrical I guess. |
Do a search on here. One of the posts has a service bulletin that might help you. Tim |
| Parameters Hi Chris, It has been a while but there are a couple of parameters and or settings that have to be correct. One of them is setting the number of coolant positions you have but I can't remember what the other one was. It they are not set correctly I can cause issues. Has anyone changed any of your settings or parameters on or about the time that the alarm occurred. Just another thing to take a look at if it applies to your situation. John |
| Changed switches still dont work.No settings or parameters were adjusted.I might have to trace the cable back to see if theres any breaks.As soon as I fired up the machine hit the power up button.She XYZ traveled home then the alarm went off It couldnt bring the spigot back up to find home. |
| Cable Hi Chris, I guess anything can happen. When I took the cover off my HAAS TM-1P to install the spigot cable I found a ground wire that got smashed during the build process. No big deal but if that happened with the spigot cable time and vibration could take its toll. Keep us up to date and let us know what you find. Good Luck! John |
| I am wondering if there is A "phasing" on the install.Do the switches need to be timed?Activated together at A certain point. wires are all good.Messing with machine manually brought it all the way down let the machine bring it back up and count the positions and it worked for 10 min,now not so.My HFO went out of buisness customer service was outstanding there,and the techs would have this resolved allready through A phone call.I dont even know if you can get parts in A timely manner here now. |
| HAAS Support My machine has an 800 number sticker on it to call for Factory Help. I think I would try that option as your HFO went out of business. John |
#10
Disconnect the cable from the unit. You can manually run the unit (by rotating the large spur gear) and check that each lobe of the small cam actuates the counting switch by listening to the click. Also you can check that the homing switch mounted on the casting actuates when the cam pushes back on it. You should also feel more resistance to turning of the large spur gear when the switch engages. If you have both switches working, chances are good that it's not the pcool. Again, make sure that the black shaft rotates freely. You said that the motor moves the nozzle, so the motor is okay. We have had I/O board issues with regards to the PCOOL circuit. This would require you to have a HFO tech out there... IF and when the tech comes out, have him demonstrate to you that the new board will work. Let me know if this helped. Please check this out:
__________________ PCOOL dude... |
#11
| Alarm code 196: Coolant Spigot Failure I was getting the coolant spigot failure alarm (code 196). After a lot of time fussing to figure out what was wrong, I determined that something was wrong with my PCOOL gear motor. There are four wires that go to the the PCOOL option. Two wires monitor a switch that closes every time a little cam toggles a switch and the other two wires output about either +10V or -10V to tell the gear motor which way to go. There is a home position switch that puts an extra 100 ohms in series with the gear motor when at the home position. I think this extra 100 ohms signals the I/O control board when the spigot is at the home position and maybe reduces the torques so it can't press too hard on the home switch. OK so the PCOOL module is pretty simple and isn't too hard to disassemble. I took mine apart and manually applied + and - 10V to the gear motor to see if it would move. The gear motor draws about 300 mA so disconnect the gear motor wire and inject the + or - 10V directly to the motor to see if you can make it move. Do this only momentarily so that you don't jam the swing arm against the limits (or loosen the swing arm collar first). On mine I determined that my gear motor would only turn in one direction (the 12V motor brushes were broken). Haas wanted to exchange my entire PCOOL assembly for $650. The gear motor that I needed is MOLON CHM-1202-2 which you cannot get (easily) from Haas or from MOLON. I did find, however, that MOLON markets the exact same gear motor under the Dayton brand which is available from Grainger for about $65. The Dayton gear motor part number is 2L004. If needed, here is a link to the replacement gear motor: Gearmotor, 1.5rpm, 12vdc - Gearmotors - Gearmotors - Power Transmission : Grainger Industrial Supply If your gear motor appears to be OK then, with the gear motor disconnected, check to see if the +/-10V signals are coming from the I/O board--these should be present at the pins where the gear motor was connected. You'll have to look with an oscilloscope because they only pulse for a short time. To make the pulses appear, disconnect the gear motor, reset the alarm an press the CLNT UP or DN buttons. I isolated my scope ground since I wasn't sure if either pin was grounded and didn't want to short the I/O board (expensive if damaged). I'm pretty sure you won't be able to see these pulses very well with a DVM--there only there for maybe a couple 100 milliseconds. You can also check to make sure the home switch is working (use an ohm meter) and check also that the cam actuated switch is toggling as the cam moves by. It should make a clear clicking noise. You may have to bend the little switch arm up or down to make it actuate this switch properly. There is also a very small Allen screw that can do this but it's too hard to get to so I just gently bend the arm until I got smooth operation. You may also have to power the machine down to force the "Power Up Restart" to do the homing algorithm. Hope this helps. I also made a PCOOL wiring diagram if anybody needs it. Tom |
#12
| I just, in the last couple weeks, had to dis- assymble my p-cool unit, for a second time. This time I had to trace the problem back to the motor itself. It seems that the brushes had too much carbon buildup, if that's what you would call it. However, it kept the brushes from making a good contact to the armature. It's kind of a trick to get the motor apart. There are three small tabs that have to be bent back to remove the motor cover. Also, make sure you take a picture of the gearbox as soon as you seperate the housing. There are quite a few gears in there to keep up with. Good luck. |
| VB System Failure?? | kbillan | Machines running Mach Software | 1 | 11-19-2008 07:01 PM |
| bridgport vmc hdd failure | jke6113 | Bridgeport and Hardinge Mills | 4 | 01-15-2008 05:34 PM |
| x axis failure | Legion99999 | Syil Products | 1 | 10-26-2007 03:16 AM |
| Component failure | len | General Electronics Discussion | 24 | 12-10-2005 11:04 AM |
| Bearing Failure | Mr.Chips | DIY-CNC Router Table Machines | 5 | 11-15-2003 11:03 AM |
