I am machining on a VF5 with 4th axis. I have to rotate the 4th axis to load each part on the fixture. Unfortunatly in hand jog mode it highlights the "H" lenght for the tool in the spindle. When I pushed the "Chip FWD" button to remove some chips while I loaded parts I must have Hit the "Tool Offset Measure" button by mistake since it is right above the Chip FWD button. This unfortunatly cleared the tool lenght without me realizing it. As you can guess as soon as I hit cycle start I buried the tool into the fixture. So does anyone have any suggestions as how to safeguard from having this happen again. |
| This puzzles me. If the tool offset is zero the tool is going to stay at the tool change height. Unless of course you have a large negative Z in the work zero so you are working your tool offsets from the table or 4th axis centerline. How do you normally set up your tool offsets?
| I use a Renishaw Probe to set the tools and work offset. This gives me a positive number for my tool lenght and the work offset is a negative number. My g54 Z 0. is the center of the 4th axis. My original T6 lenght was around 6.1 and since the machine was at tool change position (Z 0.) when I must have hit the tool offset button I lost my tool lenght. |
| When you have a positive number and accidentally erase it the tool goes too far down; with a negative number the tool stays too high, I prefer too high. I have no idea how you can guard against it happening in the future as long as you use positive tool offsets.
| WOw I never thought of this, until you 2 pointed it out, about the positive offsets, That is pretty dangerous. POS numbers are never good on machine offsets. On my machine theres a permission that if I apply number that is xx amount the machine will ask me if I am sure I want to add it, gives me a yes or no screen. it works on the fixture offsets , is your permission enabled for that? would that prevent something like this happening? its annoying but a few times I have missed a decimal cause I font have my glass's on or typing to fast and it saved my butt. Delw |
| If I type in a number it asks if I am sure and I have to hit Y to verify, but when I hit the tool offset it does not ask if I am sure. Is there a setting that I can turn on for the Tool Offset Measure to ask if I am sure because that would have prevented this from happening. As far as using the probe for setting the tools this is all I have used. I will have to spend some time and learn to set tools with out the probe. Since I have only used the probe I have never used the tool offset button so I never thought about accidentally hitting it and what problems it could create. |
| I never use the tool offset button either, only the probe. I just assumed. when I first got the machine I hit it by accident , we were using one tool to test the new spindle on some cuts(tool 1). The tech was there, I said **** that button isnt safe, he told me not to worry about it, it didnt change your setting. I said ok and left it at that. It could have been that I wasnt in the correct mode/screen? when I see him or talk to them again I will ask them about it, cause now I am curious. |
| I set my face mill as zero then make all the other tools relative to that. Some are + and some are -. Works like setting lathe tools so then you just face a piece and press the set workpiece z zero to set work Z offset. |
| Hi BBQ70 You can not do what you said happened you can not change the tool offset unless the tool offset page is open You can press the button Toolset all day & it will not change any offsets something else happened but it was not because you pressed the wrong button Just remember the Tool Off Set Page Has To Be Open For this to happen It is a rear thing that you need to have any tool set Positive No Tools should ever have to be a positive number this is a crash waiting to happen
__________________ Mactec54 |
#10
| mactec54, When I push the hand jog button the tool offset screen in the top right turns white and the memory screen on the left side turns blue with the machine offset screen lower right stays blue. It also highlight the tool that is in the spindle, which for me is t6. Every time I then push the Tool Offset button it changes the tool lenght to 0. since I am at tool change position ( home ). I have repeated this several times to verify what had happened and it always does the same thing. |
#11
| I'm pretty much with Geof for the same reasons.....old school reasons, but there were reasons for the reasons ![]() Is setting 64 the one you have to change "tool offset measure uses work" if you want to use negative offsets? I don't use a probe and mine is "off". However, I think if you have 64 "Off", then Offset measure does not perform a useful function in setting a Z0 in the workshift, but its still useful for X and Y. At least as far as I know, I have to measure the distance from the tool setting plane and the Z0 of the part, and type in the Z value per each workshift. I don't see why you could not use a probe and also have 64 off. It should then ignore the distance between the gauge plane of the spindle and the tool, which is why it is giving you positive tool lengths. But I'm asking this, not suggesting it, because I've not played around with it.
#12
| Short of changing the way you get your offsets by probing ,( I say if your familar with doing something one way keep doing it that way).The only thing I can think of whould be to turn on setting 119, it is a offset lock.Sure beats crashing
__________________ Just push the button,what's the worst that could happen. |
| Need Help!- Offset, measure the first tool and second tool | domax | Daewoo/Doosan | 14 | 12-29-2009 11:20 PM |
| Changing tool diameter in the tool offset screen | Vern Smith | Haas Mills | 21 | 09-24-2008 10:54 AM |
| Problem- Tool bit offset | AngelT | Mach Mill | 3 | 06-29-2008 11:42 AM |
| Tool Offset (G45,G46,G47,G48) | jorgehrr | G-Code Programing | 6 | 11-13-2007 02:54 AM |
| Tool Offset | 3rdcoast | Mach Software (ArtSoft software) | 1 | 05-19-2006 02:08 PM |
