Results 1 to 7 of 7
Thread: What does G52 do ?
    May 2007
    What does G52 do ?
    I'm trying to run a program and move over 4 inches and run the same program
    but tell the machine to reset the G56 and restart the program
    Ill post all the code in it ..
    any Ideas
    Jul 2005
    G52 creates a local work zero with reference to the active work zero.
    You are using G56 to machine something and then want to repeat the program 4 inches over.
    Make the program a subroutine and call it after selecting the work zero.
    O00000 (sample prog)
    all the normal stuff
    G56 M97 P1000 (set G56 and go to subroutine)
    G52 X4. Y0. Z0. (return from subroutine and set a G52 work zero at X4.)
    M97 P1000
    M30
    N1000
    Your program
    M99
    You could also do it be resetting G56 using a G10 command.
    May 2007
    Quote Originally Posted by Geof View Post
    M97 P1000
    M30
    N1000
    Your program
    M99
    Thanks a bunch ...I'm going to make some test programs
    The program I want to do is on the Hard drive and 6 megs
    Jul 2005
    Quote Originally Posted by kojack View Post
    Ah, that might create problems. You are going to DNC from the hard drive? I don't think you can use subroutines the same way as you can when the program is in the machine memory.
    Jul 2005
    Somehow or other I double posted so I deleted this one.
    Nov 2006
    Why not just use a G10?
    Jul 2005
    Quote Originally Posted by timan View Post
    Because I don't want too.
    Using G10 to reset your primary work zero is entirely equivalent. My main reason for not using G10 is that if you stop a program part way through you are left with whatever the current coordinates are in your primary work zero and this could cause problems. G52 is zeroed when RESET is pushed so you are back to your known work coordinates.
  • Posting Permissions
