Old 08-08-2009, 12:15 AM
crabbass is on a distinguished road
program message
Question,
On some controlls it is possible to display an operator message. I havn't read into this on the haas controll. I would like to write a macro for probing a inside width in x, and subtracting the difference from the work offset I am using. I do not want to shift the work coordinates, just check the positioning accuracy of the fixture each time. I want to have a program stop M00 after probing and see on the "current comands" screen the difference in the probed center in x compared to the work offset. Or use an "if" statement to create an alarm if the difference is greater than say .0015". If the "if" statement is smaller than .0015" the program would continue to run.
Most of you would ask , why not just update the current work offset?, The part is not flat on any side, the fixturing I have designed locates on a radius. If the part "rotates" it also shifts in X axis location. The fixture has a mechanical centering device that should locate the part within a couple of tenths (centered in X). I guess I could create a macro that would also trig the angle it is rotated and use coordinate rotation. This might not satisfy my accuracy as the radii are verry large, and .001 degrees would be a larger shift than a x axis .0001" shift.
Anyways , any input on messages, it is something I have been curious about.
thanks.
Old 08-08-2009, 12:25 AM
dcoupar's Avatar
From the Haas Mill Operator's Manual (p. 91)
Name:	Haas Macro Stop w Message.jpg‎
MESSAGE CNC1970 CamSoft Products 4 03-08-2008 12:50 PM
E.009 Message Help toby51 Machine Problems, Solutions , Wireless DNC, serial port 0 01-16-2008 02:51 PM
E.009 Message Help toby51 General CNC (Mill and Lathe) Control Software (NC) 0 01-16-2008 04:45 AM
HOw can I tell if PC-2 is getting message from PC scheek Mach Software (ArtSoft software) 1 04-13-2006 10:36 PM
Why can't I put **********.com in message? samualt Forum Questions or Problems 12 09-12-2004 10:52 AM
