Old 08-07-2009, 07:25 PM
southernexplore is on a distinguished road
VF-2 stops in the middle of a program!!
When I simulate a 3-d part on the VF-2 it stops about 3/4 of the way through
the program. When it stops it locks up the machine and I have to shut it down to reset it. Anyone have a clue to why it just stops. When I load the program I have 20% memory left. The program is about 25000 lines and it runs to line 18751 approx. but it is the same line every time. The line where it
stops is just an x y and z move with nothing special.
Thanks,
Tommy
Old 08-07-2009, 10:43 PM
HuFlungDung's Avatar
Moderator
Do you only have the one program in memory? IOW, could you make some more room by removing some programs to see if that makes a difference?
Other than that, I'm not sure. Does cutter comp happen to be active in the area where the hang occurs? I've had the odd instance where the machine would stop moving during a compensated path, but it is rare.
What version is your Haas software? That might help someone diagnose the problem.
Old 08-07-2009, 11:36 PM
Thanks for the reply.
The machine is original to 1990 I believe. I could try and clear all other programs and there is no cutter comp. involved. It is just cutting with a .25 ball nose endmill, standard 3-d moves. Is there any parameters that would stop it from running a set number of lines(just a guess)
Tommy
Old 08-08-2009, 04:15 AM
Superman's Avatar
Superman is on a distinguished road
A lot of controls read ahead a certain number of lines, are you sure that the line it stops on is the problem, or one that has just gone into the buffer ??
Going into single step just before the "bad" area and stepping through would fine tune the actual offending code if it exists, as the read ahead function is a bit more restricted.
Old 08-09-2009, 12:30 AM
I will try to step into it and see!
Tommy
Old 08-12-2009, 10:18 AM
Mic6's Avatar
Mic6 is on a distinguished road
Is there a remote possibility you have a feed rate with no decimal point? Considering this large program was posted and has been running, I doubt it left out a decimal, but it's had me stumped before.
Old 08-12-2009, 01:34 PM
To answer the question on feed rate without a decimal, nothing was missing, it was running a 3-D program that had the same feed rate for approx. 20,000 lines.
I give up on that drawing and g-code post.
I made some changes to the drawing and was able to cut it with no problems.
Thanks for the help everyone!
Tommy
starting in the middle of a program panaceabea Milltronics 11 05-19-2009 09:54 AM
locked up in middle of program nmn Haas Mills 9 03-30-2009 10:33 PM
starting from the middle of a program panaceabea Haas Mills 8 03-27-2009 07:31 PM
Starting in the middle of a program.Old control. lostkoss General CNC (Mill and Lathe) Control Software (NC) 3 10-07-2008 10:11 AM
Hass VF6 how do you stop in middle of program SpringKing Haas Mills 5 05-14-2007 11:07 AM
