Old 08-06-2009, 01:27 PM
slatern44 is on a distinguished road
Alarm 235 spindle Z fault, encoder belt?
Today I keep on getting an alarm 235 spindle Z fault if I put my rpms above 5000 on my mini mill. I have another encoder belt that I am going to put on now but was wondering if anyone has some info on changing it? how do you make sure that it is oriented correct? If that’s not the problem next replace the cable or is there something else that I am missing?
Thanks.
Old 08-10-2009, 04:28 PM
Put a new encoder belt on this morning, got the spindle oriented and it ran fine for about 5 hours now it back getting alarm 235. Is it the encoder or something else? anyone else have alarm 235???
Old 08-17-2009, 02:54 PM
Loose Nut's Avatar
Loose Nut is on a distinguished road
Probably the spindle encoder. Unless you have a methods for checking one or know someone who can your best bet is to try and replace it. Before you do, inspect the cable and connectors carefully.
Loose Nut
VF3 spindle high gear fault alarm #117 help! JHR1 Haas Mills 14 01-01-2010 11:39 AM
spindle encoder belt RICKG Fanuc 2 10-22-2007 07:14 PM
Alarm 123 Spindle Drive Fault Shotout Haas Mills 11 05-27-2007 12:48 PM
Alarm 235 Spindle Z Fault Gomes Haas Mills 1 04-27-2007 12:26 PM
Alarm 408 Spindle Serial Link Start Fault boricuajdm Fanuc 1 04-23-2007 01:26 PM
