Old 08-06-2009, 04:03 AM
timmydabull is on a distinguished road
tm1p spindle air leak
i noticed a small air leak in the set screw on the side of the spindle last week and it has seemed to progressively get worse,and tonight i notice air leaking around the spindle.
i did a post search and couldnt find any info other than it should cut off shortly after spindle stops (which it doesnt)
seem to notice some potential maintenance issues just about everyday now.
anyone have anysuggestions whether i should fix it or leave it alone?
i also have several toolholders from various sources that some come out of the spindle like you are hitting the top with a hammer when you press the tool release button and others you cant feel them disengage.
are these issues related and are the belleville washers going to be the first place i start looking?
thank you in advance.
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
Old 08-06-2009, 09:30 AM
Originally Posted by timmydabull View Post
....i also have several toolholders from various sources that some come out of the spindle like you are hitting the top with a hammer when you press the tool release button and others you cant feel them disengage....
Have you thoroughly cleaned the spindle taper and the toolholder tapers? Over time a coating can build up from evaporated coolant and this can cause the holders to stick in the taper. Also it is my experience that some holders will stick more than others even when they are really clean and just have a light oil coating. This difference often shows up between holders when they have bee working hard in a heavy cut.
Regarding your air leak the only comment I can make is that it could be a sticky solenoid valve. Is your air supply clean and dry?
Old 08-06-2009, 09:38 AM
Loose Nut's Avatar
Loose Nut is on a distinguished road
Tim,
The air you feel coming out of the spindle is a positive air flow and the small air regulator for it is behind the machine. It should be set to 17psi. It should only occur when the spindle is running and for a minute after it is stopped.
The air regulator sits directly behind the main air regulator and is controlled with a 115vac solenoid valve.
If your valve is stuck open, the air purge will be on continuously. This is more than likely caused by a bad air supply to the machine. Moister in the air supply washes the pre-lubed valve clear of lube causing the valve to stick.
The machine should have a clean dry air supply. If not you will need to expect problems.
Are your tools sticking in the spindle? Or the noise you described, is it in the headstock area above the spindle behind the cover?
Try cleaning the taper of your tools and the taper of your spindle with Scotch-Brite and light oil.
What are the, "potential maintenance issues," that you are having. Other than cleanliness and grease the TM series of machine is pretty much maintenance free.
Let us know how it turns out!
Edit to Add: ! Damit Geof, beat me by a minute!
Loose Nut
Old 08-06-2009, 12:48 PM
axis is on a distinguished road
are the tm1p spindles not grease packed , like the tm1. if they are oil feed then air will come out the set srew on the side and out the bottom of the spindle the tm is also famous for sticking tool holders some sound like a shotgun going off coming out of the taper and others sound like a feather droping been running my tm for 6 years. keep the tools and spindle clean and you should be good to go
Old 08-06-2009, 07:53 PM
i havent cleaned anything in 6 months guess its time,how do you go about cleaning the spindle and toolholder tapers?
thank you
ps
the drain on my air compressor the other day when i went to drain excess water from the tank was stopped up with sludge,havent figgured out how im going to fix that issue yet.
normally i have been very persistent in draining all water filters in the tank and on the system on a daily or bi daily basis.
i have been working very hard for the last several months and i may have been lax in maintaining our equipment working from 9 am to 3 am 7 days a week is getting to me
Old 08-06-2009, 08:02 PM
Originally Posted by Loose Nut View Post
Tim,
Loose Nut
i checked the regulator and is set to 17psi gauge pressure.
i have been getting moisture in the air supply recently due to reasons mentioned above although i have a trap at the compressor and another at the machine.
the tools are sticking in the spindle,i will clean them using the methods you described.
i recently have had to replace the ballscrew cover,noticed the airleak in the spindle,compressor drain issues(sorry no related to machine) and the y axis is louder than the rest of the axis travel.
dont know what to do on that one i noticed a piece of fiber in the back of the y axis linear guide cover and i highly suspect it is maybe a wiper of some sort. (dont know what i should or shouldnt do regarding linear guides)
Old 08-06-2009, 08:05 PM
yes grease packed,although i grease routinely the grease mrely squirts out the side of the zirk fitting,dont know if its full or i am doing something wrong
will start keeping tools clean as i can,i have been using my liquid ice coolant very rich recently and i had to remove and reinstall my chip auger as it was losing 5 gallons a day from a bad seal at the motor when the tech came out and installed it.
Old 08-06-2009, 08:07 PM
i want to personally thank all of you for your replies and help,i am a firm believer in (and i spend my life) helping others.
hopefully i will be in a situation to give back one day.
thank you
Old 08-07-2009, 01:22 AM
i havent cleaned anything in 6 months guess its time,how do you go about cleaning the spindle and toolholder tapers?....
I use methanol to take off the coolant residue and Varsol to take of oil and grease residue. For the spindle wad up a piece of cloth, I use old towels, soak it with either methanol or Varsol and just rotate it inside the taper.
Old 08-07-2009, 04:13 PM
bigbaz is on a distinguished road
tm grease gun
When i first got my tm2 i had the same problem when greasing the xyz ways, grease would leak out around grease nipple making me worry if the grease was going into the trucks, so i bought a new end for my grease gun and all the grease goes into the machine without any leaks.
  #11   Ban this user!
Old 08-09-2009, 02:14 AM
i will do
thank you Geof
  #12   Ban this user!
Old 08-09-2009, 03:38 AM
SlowRiderr is on a distinguished road
Check to make sure it isn't rusted after you clean it. I used 2000+ grit sandpaper oiled with WD40 and turned the spindle CW at a low speed and cleaned up the internal taper on my machine.
The spindles are the same for TM1 and TM1P. The TM1 has different max rpm and frequency numbers in the parameters.
Water cooled Chinese Spindle - air leak analogman DIY-CNC Router Table Machines 14 03-02-2010 04:22 PM
Puma 600/700 coolant leak from turret jani Daewoo/Doosan 6 02-20-2010 08:03 AM
Need Help!- TM1P question RB Precision Haas Mills 24 05-08-2008 08:38 AM
Brand new VF-2 and I have a coolant leak akedward Haas Mills 13 11-19-2007 12:28 PM
newbie and a new tm1p timmydabull Haas Mills 58 09-30-2007 04:32 PM
