#15
| I know the age and model make a difference but my TM-1P kept the spindle air flowing constantly when I first got it. The compressor ran all the time. Fortunately, a friend of mine knew the electronics well enough to tell me how to wire the air valve on the small regulator into the timed circuit which will shut the air off after the spindle stops. There is a parameter that controls the delay. I can not figure out why Haas would want the air to be flowing through the spindle when it is not turning but I'm sure they have one. I have mine sete to flow for 20 seconds after the spindle stops which will cover any tool change. Vern |
#16
| looks like i will be getting a new grease gun tomorrow. thanks
__________________ 2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX |
#17
Any chance you'd be willing to share your schematic? Chris |
#18
| Please remember all these machines are not the same so this information only pertains to my 2006 TM-1P. You are on your own with your particular machine. This is a layman's disclaimer, lawyers charge lots of money to say the same thing in 4,000 words or more. ![]() The circuit we used was the spindle fan off delay. It is controlled by parameter 208. The wire you want is the one coming from the small air regulator. Below is a picture of the tag on mine. The pin on the power board you want is P-41 on the bottom right corner, it is clearly marked and labeled spindle fan. You can see in the second picture the pin and board. In front and out of focus are the auto store splices I used to graft the air regulator control wires into the spindle fan control wires. This way they share the same pin or board connection. Good luck. |
#19
| bought a handheld grease gun today with flexible hose and i must say it seems to work much nicer than the gun that came with the machine.
| Water cooled Chinese Spindle - air leak | analogman | DIY-CNC Router Table Machines | 14 | 03-02-2010 03:22 PM |
| Puma 600/700 coolant leak from turret | jani | Daewoo/Doosan | 6 | 02-20-2010 07:03 AM |
| Need Help!- TM1P question | RB Precision | Haas Mills | 24 | 05-08-2008 07:38 AM |
| Brand new VF-2 and I have a coolant leak | akedward | Haas Mills | 13 | 11-19-2007 11:28 AM |
| newbie and a new tm1p | timmydabull | Haas Mills | 58 | 09-30-2007 03:32 PM |
