Old 07-30-2009, 12:42 PM
behindpropeller is on a distinguished road
Form Tapping
I'm looking for some advice on form tapping. What is a good RPM for a TM series mill? What is the largest suggested form tap?
edit: Material will be 6061T6
Tim
Old 07-31-2009, 08:32 AM
Get lucky's Avatar
Get lucky is on a distinguished road
I don't form tap any thing over 1/4 with a form. speed all depends on wear in the machine but most of my tapping cycles are running at about 1400 rpm's with quality taps.
Kyle
You must remember that 99% of my posts are Bullchit!
Old 07-31-2009, 09:19 AM
1ctoolfool's Avatar
1ctoolfool is on a distinguished road
form tapping aluminum
I have tapped up to 1/2-13 with OSG thread formers all day long at 1000 rpm with no problem with a VF-2. Make sure you use the right starting hole diameter and gracious chamfer as the form tap will upset material upward. for instance recommended .460" start hole for 75% thread for 1/2-13. I use .470" (vs. .421" for regular tap)
osg website has a calculator for form tap hole sizes.
http://www.osgtool.com/Technical.asp?tid=1&id=1
I would form tap larger if the taps were available, hard to find larger than 1/2"
also i have thru tapped (normal gun-type tap) 3/4-10 into 1/4" mild steel at 500 rpm with a TM-2 no problem. single pass with slightly oversize tap hole.
Old 07-31-2009, 03:37 PM
bigbaz is on a distinguished road
FLUTELESS TAPS
Use a top quality cutting fluid or you will break taps.
Roll form tapping questions stebanski Haas Mills 10 05-11-2011 05:12 PM
tapping on a mini mill without rigid tapping??? mls Haas Mills 13 07-03-2009 07:43 PM
Tapping with the Tormach Tapping Head bobs_charger Tormach PCNC 0 04-24-2009 05:08 PM
Tapping head or rigid tapping Gregory_C Syil Products 2 10-18-2008 01:49 AM
tapping head vs hand/cordless tapping machine.... InspirationTool General Metal Working Machines 6 09-12-2005 09:10 PM
