#13
| I'm looking at the Kaeser 5C. http://buykaeser.com/store/product_i...products_id=30 I believe this one cycles the motor on and off as well from what I can tell. Any good suggestions on the scroll compressors? |
#14
Atlas Copco is one. But seeing that you are looking at a 5 hp, the aforementioned staged units don't really come in to play until you start looking at multiples greater than five (typically multiple 5 hp units). Atlas also offers dryer and scroll compressor packages, unsure if any of them include a receiver tank. As an all in one, the Kaeser your looking at looks like a fair deal. A similarly equipped scroll package with tank might end up being a little bit more money, but I don't know for sure. |
#15
| I was wondering if anyone here uses a rotary vane compressor? In a plant where I used to work we had a 75HP Hydrovane that ran 24/7 except when we stopped it to do preventive maintenance. I was impressed with its reliability. Here's an example I found on eBay: http://cgi.ebay.com/CompAir-Hydrovan...d=p3286.c0.m14 Ralph |
#16
| 123cnc, thanks. Yep, the Kaeser just looked like an awfully nice all-in-one unit. Compact, components designed to work together, apparently a good brand. Luckily they have a storefront here in Houston so I'm going to stop by next week to take a look at one. |
#17
| I have vf-3 2006 20hp and a 2002 mini mill standard 7.5hp I only have 100 amp running to my garage and only 200 amp in house I have never had any problems yet. I run the phase perfect I put a 100amp breaker to it I run the vf-3 and my bridgeport off of this and the mini mill of single phase these both run at the same time all day long with the saw, bridgeport , and my ingersal rand 60 gallon 3hp compressor no problems yet 1.5 years. I cheaked the power draw at the machine when I installed it (vf-3) and when it starts the spindle from 0-7500rpm it only pulled I think it was like 17 amps the 50 amps would be every motor at peak power. I have since built a cnc plasma cutter with a 60 amp hypertherm torch unit and use this while running everything else except the mini mill with no problems. I hope this help I would get the second size converter ($4000 one) and get a 5hp compresser (unless you will be blasting all day long). Good luck Mike |
#18
| mls, which phaseperfect model are you using? After talking with my electrician I too am thinking I might not have to bring in another 200 amps of service. The question is what the peak draw is on my house at the moment. I just ordered one of these nifty devices to hopefully answer that question: http://www.theenergydetective.com/what/overview.html and here's a review of the unit: http://inspiredaustin.com/blog/2009/...rgy-detective/ |
#19
| I checked the peak current into a VF2 just for spindle starting and it was 50amps but this check was done using a scope.
#21
| We run rotary Phase Convertors one for each of the mills and lathe. I fried the Fanuc control on the lathe trying to run both off the same 30hp convertor. Sometimes you can send wild phases back through your system by reversing a spindle and that is what kill the Fanuc according to the repairman that came with a load of parts to switch in and out until he got us working. Cha-Cheng. Each convtor is on an 80 breaker and of course they are never all started at the same time. I switch each on on after the previous one has reached full speed. I also got in trouble with my PUD for running too big of a motor on a residental service even though I had contracted for a 320 amp service for the house so I could wire the shop when we built it. We had to bring in a commercial 320 amps for the shop plus buy a new transfomer for the feed. Make sure you have read the fine print from your power supplier. Lowell |
| wtb: 20 or 30 hp phase perfect phase converter | gaugemate | Want To Buy...Need help! | 0 | 10-23-2008 12:06 PM |
| phase converter | rob jerico | Fadal | 13 | 09-02-2007 12:32 AM |
| HELP rotary converter for air compressor | gman1487 | General Electronics Discussion | 0 | 06-03-2007 11:22 PM |
| DIY phase converter? | wyobmf | Phase Converters and VFD | 9 | 07-26-2006 04:37 PM |
| RF from phase converter ? | DieGuy | Phase Converters and VFD | 1 | 10-20-2005 07:14 AM |
