#37
| Why would it be unacceptable? If you have a master mounted on the table and check that with the probe and then check the part and have it dump the numbers off of both parts into an inspection sheet. If the master is correct why would the part be off?
If the technology is there you might as well use it. How come you are not making parts with a manual bridgeport anymore? You got dummed down to using a CNC. Tim |
#38
If you are talking retirement I can highly recommend it. I have been retired since 2000 and having the time of my life doing what I want for whom I want and when I want. Go for it. John |
#39
| machines have wear surfaces and they do wear under heavy load and the different materials you cut, not to mention the slop that a ball screw will give after a why. CMMS are run off of air bearings, there is less friction and there not used as a cuttin tool, which will cause wear points. put a .00005 indicator on your machine and push the table and the head you will see the needle move, even on a new machine. however under a load the machine will hold a tol. While haas does cut a good circle its not perfect interpilation. dont be so sure, I use mine every day for making parts and drilling, every piece of equipment has its usage. |
#40
| John; Yes retirement, years ago I said I never would but now I have gone and done it. ![]() The parts I like are the two upcoming river cruises in Europe later this year and several trips planned for next year.
| HELP!! Haas Super Mini Mill | CountBraden | Haas Mills | 4 | 07-06-2008 06:20 PM |
| HAAS Super Mini Mill | Ford25 | Haas Mills | 13 | 09-07-2007 08:01 AM |
| Super mini mill/coolant tank | taylors | Haas Mills | 8 | 02-19-2007 07:33 PM |
| help with super mini mill please | daleman | Haas Mills | 12 | 08-14-2006 02:32 PM |
| part for super mini mill | daleman | Haas Mills | 0 | 05-04-2006 01:03 PM |
