Old 07-18-2009, 10:11 AM
mike cncmachine is on a distinguished road
g70 bolt cycle code
Hi All,
Can any one explane how the haas mill g70 code works. the manual do not have a sample code and i cant get vcq code to work ( probably a faulty operator). I have got it to work by adding a g81 befor the g70 but i dont want a hole in the middle of my bolt cycle,
Thanks Mike
Old 07-18-2009, 01:04 PM
You set up the drill cycle but put L0 in the line and follow it with the G70 like this:
G81 Z-.2 F20. R.02 L0
G70 I J L
Read your manual it is all in there. If you don't have a manual you can get a pdf file from the Haas website, go and find it.
Old 07-18-2009, 01:23 PM
Thanks Geof,
I knew it was some thing simple
where can I BUY this BOLT bluechipmfgllc CNCzone Club House 1 06-01-2009 09:57 AM
How to build cycle in g-code s_volenszki G-Code Programing 14 12-29-2008 03:15 AM
M Code in Canned Cycle Question banausicjosh Fanuc 2 08-27-2008 04:03 PM
Bolt size ? dropride Bridgeport and Hardinge Mills 2 06-17-2008 07:38 AM
PLEASE HELP Get this bolt out....please....Im desperate... diarmaid General Metalwork Discussion 25 07-01-2006 04:07 PM
