Old 07-17-2009, 01:33 PM
big_mak is on a distinguished road
4th Axis Rotary, Brush or Brushless
How can I tell the difference from a brush or brushless Haas Rotary unit?
A neighbor has one that I could borrow, but I need a brushless to run on my machine, and it is an older model.
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 07-17-2009, 01:41 PM
pants is on a distinguished road
Look at name plate. example:HRT 210B
B = brushless!!!
Al_The_Man's Avatar
If you can take a look at the motor, the brush holders are usually visible to the outside, either 2 or 4 at the rear of the motor.
Not always applicable, but if it is a square motor body with heat sink ribs, it is DCBL or AC.
Or even the drive itself could be marked with the type.
A DC drive has two power conductors to the motor, DCBL/AC has 3.
Old 07-17-2009, 03:04 PM
you can still run a brushed motor from brushless drive amp. Just need a conversion kit.
Old 07-17-2009, 03:24 PM
Brush type has a single plug, brushless has two plugs. You can get adaptor boxes to go both ways I think; brush type on a machine with brushless 4th and brushless type on a machine with brush 4th.
Send me a PM if you do not get sorted out it is possible we have an adapter not currently in use.
Tags
4th axis, haas, mill, rotary
Just IN- Techsoft Motion Control,Low cost,Brush/Brushless Servo Motors,drives/controllers Ling Product Announcements & Manufacturer News 0 07-15-2009 09:50 PM
Axis Motors Brush replacement Delw Fadal 11 02-11-2009 11:35 AM
Need Help!- X-Axis VF-0 Brush Motor lkenney Haas Mills 5 11-13-2008 12:32 AM
Brush or Brushless Nilad Gecko Drives 4 09-05-2006 10:00 AM
PacSci SIGMAX E32 hybred motors... Are they Brush or Brushless? ngr1 Stepper Motors and Drives 3 10-15-2005 02:59 PM
