Old 07-09-2009, 06:40 AM
omy005 is on a distinguished road
Question VF2 SS tool change failure
G'day all, Our HFO has just replaced the entire tool changer cam box assembly (haven't received the bill yet!) on our machine with about 620,000 tool changes on it. A bearing had collapsed inside they think as one of the shafts was wobbling around a lot and we we're getting TT over load alarms. Factory said it's not a serviceable item?
Has anybody else had one fail?
Our other VF2SS has done over 1,300,000 tool changes with only one fault (carousel motor brushes).
Andrew.
VF3+TRT210, VF3, VF2+HRT160, VF2SS+TR160, VF2SS+TR160, VF5TR, VF5TR, VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS
Old 07-09-2009, 09:47 AM
I have several Haas machines with both carousel and side mount changers and so far no catastrophic failures, just a loose bolt or two and dirty proximity detetctors. But even my oldest machine, a 2000 VF0 has nowehere near 620,000 changes, never mind over a million; what are the total hours on that machine? A toolchange is around 3 seconds so a machine with 1,300,000 tool changes has spent over 1000 hours just changing tools!
Old 07-09-2009, 03:39 PM
rlabonte18 is on a distinguished road
We have had a few failures on some machines, now as soon as we get a new haas in the first thing we do is slow the arm down and hadn't had a problem since doing this. It is not noticable in the cycle time and sounds to me much nicer. If I can remember right it is param 469 factory setting is 1470000 and i have been changing it to 1000000. we also check the oil level monthly.
orient tool for tool change Hall effect? Luslugger CNC Machining Centers 0 04-24-2009 07:24 PM
Need Help!- Fadal 4020 Z axis tool change failure ssurfview Fadal 1 05-15-2008 07:48 AM
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 03:58 PM
Tool unclip failure Shotout Haas Mills 4 08-09-2006 09:03 PM
Tool Turret Index Failure hatchmar Machine Problems, Solutions , Wireless DNC, serial port 6 06-09-2005 07:36 PM
