I'm having a problem with a very simple dill and tap operation. I feel like a dork, but I haven't done and drilling and tapping in stainless since I got this machine so I'm kind of in the dark. So far I've broke a center drill and rounded off a drill. So if someone could take a look at my program and tell me what I'm doing wrong I would appreciate it. Oh and my mill is a HAAS TM1 % O7809 (shift plate for guys next door.) T1 M06 D01 (#2 CEN DRILL) G00 G54 G90 X-1.0 Y1.0 S1200 M03 G43 H01 X.375 Y-.250 Z.1 M08 G83 Z-.250 Q.020 R.1 F5.0 X1.0 X1.625 M09 G80 G00 Z1.0 T2 M06 (.242 DRILL) S1000 M03 G00 G54 G90 X.375 Y-.250 G43 H2 Z.1 M08 G83 Z-1.100 Q.025 R0.1 F5.0 X1.0 X1.625 M09 G80 G00 Z1.0 T3 M06 (G DRILL FOR 5/16-18) S1000 M03 G00 G54 G90 X.375 Y-.250 G43 H3 Z.1 M08 G81 Z-1.050 R.1 F8.0 X1.0 X1.625 M09 G80 G00 Z1.0 T4 M06 (5/16-18 TAP) G00 G54 G90 X.375 Y-.250 S288 G43 H4 Z.1 G84 G98 Z-.500 R.100 F16.0 X1.0 X1.625 G80 G00 Z1.0 G00 X.375 G84 G98 Z-.850 R.100 F16.0 X1.0 X1.625 G80 G00 Z1.0 T5 M06 (.500 c-sink) G00 G54 G90 X.375 Y-.250 S1400 M03 G43 H5 Z.1 M08 G81 Z-.210 R.1 F20.0 X1.0 X1.625 M09 G80 G00 Z1.0 T1 M06 M05 M30 % ( .500 thick 2.0 wide 304 stainless, XY0 left upper corner)
__________________ Poor planning on your part doesn't constitute an emergency on my part. |
| I would cut the RPM on all drilling down about 50% and take much larger pecks. If possible do not peck with 304. T1 = no peck, T2 = 0.250 peck. Pecking and dwelling in 304 is a sure fire way to ruin tools. Peck little or not at all if possible. Flood coolant!!!! |
Hi, I have had the best luck drilling 304 by holding the sfm at 48. #2 c'drill rpm looks ok I would probably start at 1000 rpm feed 1 ipm use g83. use good quality c'drill .242 drill rpm = 757 feedrate start at 1 ipm maybe you can go 1.5 or 2 peck .03 - .04 .261 drill rpm = 702 feed start 1-2 ipm peck = .1 I know guys that can drill faster but I have found that the tools will actually last a while keeping close to these parameters use the best cobalt drills you can find use proper coolant mix. if you want to try to speed up job then increase feed instead of trying to increase rpm. good luck |
| Thanks for the help guys. I'm not to worried about how long it takes, I just need to get the parts done with out killing my tools. I would have ordered some nice tools for the job but it's a last minute deal I took to help some guys out. So, nom I'm under the gun using a HSS c-drill and non coated drills. ![]() So, I need all the help I can get.
| c'drill should be ok. decrease rpm about 20 % to start. the feeds should be ok just keep the chips coming and dont let the drills turn red and you should be fine. Also please show anyone how we do this or we will have to kill them. billy |
| Well with the hepl from you guys I got 1 good part so far. Here's what the porgram looks like now. What'cha think. % O7809 (shift plate for guys next door.) T1 M06 D01 (#2 CEN DRILL) G00 G54 G90 X-1.0 Y1.0 S400 M03 G43 H01 X.375 Y-.250 Z.1 M08 G81 Z-.250 R.1 F2.0 X1.0 X1.625 M09 G80 G00 Z1.0 T2 M06 (.242 DRILL) S400M03 G00 G54 G90 X.375 Y-.250 G43 H2 Z.250 M08 G83 Z-1.100 Q.250 R0.250 F2.0 X1.0 X1.625 M09 G80 G00 Z1.0 T3 M06 (G DRILL FOR 5/16-18) S400 M03 G00 G54 G90 X.375 Y-.250 G43 H3 Z.225 M08 G81 Z-1.050 R.225 F2.5 X1.0 X1.625 M09 G80 G00 Z1.0 T4 M06 (5/16-18 TAP) G00 G54 G90 X.375 Y-.250 S288 G43 H4 Z.1 G84 G98 Z-.500 R.100 F16.0 M00 X1.0 M00 X1.625 M00 G80 G00 Z.1 G00 X.375 G84 G98 Z-.700 R.100 F16.0 M00 X1.0 M00 X1.625 M00 G80 G00 Z.1 G00 X.375 G84 G98 Z-.850 R.100 F16.0 M00 X1.0 M00 X1.625 M00 G80 G00 Z1.0 T5 M06 (.500 c-sink) G00 G54 G90 X.375 Y-.250 S1400 M03 G43 H5 Z.1 M08 G81 Z-.180 R.1 F20.0 X1.0 X1.625 M09 G80 G00 Z1.0 T1 M06 M05 M30 % ( .500 thick 2.0 wide 304 stainless, XY0 left upper corner)
#10
| I center dill out of habbit mostly and not wanting the holes to be off. As far as the other I don't think I have the HP to pull a .262 in SS, 1" dp, it's only a TM1.
| Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. | Geof | General Metalwork Discussion | 47 | 02-01-2008 02:32 PM |
| anyone have a Fanuc drill mate or robo drill? | goodplastics | G-Code Programing | 1 | 07-22-2007 11:36 AM |
| fanuc drill mate / robo drill post for enroute? | goodplastics | Post Processor Files | 0 | 07-19-2007 06:49 PM |
| Drill holes with end mill or twist drill ? | Argofanatic | General Metalwork Discussion | 15 | 12-29-2006 11:05 PM |
| Can I drill AISI 1020 plate steel with a drill bit? | Apples | General Metalwork Discussion | 2 | 02-01-2006 12:15 PM |
