Hi Guys, I have a 2000 Mini Mill that I bought a few years ago and it has been great. I mostly just cut aluminum ( I make prototype molds part time). I have it hooked up as single phase in my garage. I just received the following errors: 292 320V Power supply fault - incoming line voltage is above maximum 177 overvoltage shut down Does anybody know what this could be and how is Haas service (price wise) Thanks. |
| It's summer time. My power company pushes up the line voltage during the summer to get more energy out to their customers during hot parts of the day. I've seen it vary from 110 to 121V per leg, in a single day. I'd take a good look at that line voltage.
__________________ Greg |
| Well, there is no 'think' in this case; either it's a vector drive machine or it's not. You need to figure out which. Vector Drive: rectifies high voltage, 325VDC power for all of the axis amplifiers in the machine. It also controls the spindle--it's the spindle drive amplifier. It says "Vector Drive" right on it. It controls all of the spindle's actions (speed, position, braking). Non Vector Drive: these machines are slightly different. The incoming power goes through a box in the same spot as the Vector Drive. In this case, that box is nothing but a 325VDC power supply. It has a rectifier bridge and some capacitors in it. From there, it takes power over to the axis amplifiers. In a non vector drive machine, they use a high-output amplifier to control the spindle. Other than the increased amperage, it looks just like the X,Y and Z amplifiers. How are you with diagnosing electronics and finding & replacing components? There are voltages inside that cabinet that can easily kill you and maybe even light you on fire (no, I'm not kidding). Those voltages are even present after shutting off the power (stored in the capacitors in the power supply). Don't touch anything unless you absolutely know what you're doing.
#10
The incoming voltage has been constant over a couple of hours so I don't think there is a spike. Is the order of the codes the sequence of failure events? |
#11
| Well, I'm not wanting to type out every possible failure because then you're going to have to read through it all, comprehend it and figure out which problem is yours. The short version: I think you have a Vector Drive, it's toast, you're about to have your wallet removed through your left nostril and $4000 will be extracted and given to Gene's Nascar team (sorry...that's probably what it is. ).The longer version: You had two errors: voltage related and spindle drive fault.
Edit: one more question--what kind of phase converter are you using, did you measure the voltages inside the Haas cabinet and are all three legs the same? You still need to be absolutely sure that it's not something simple like an incoming power problem, loose ground or other simple failure.
#12
| Ok, good news I suppose - its not vector drive. I did not check the voltage in the machine yet. I will go that route when I get home from work. I did notice on the 320V power supply the error code is "A" which said incoming AC fault. |
| Need Help!- Cincinnati Milacron Acramatic 2100 Power Supply Failure error | Wurmwood | General CNC (Mill and Lathe) Control Software (NC) | 3 | 06-24-2010 08:10 PM |
| Need Help!- Bridgeport mill power supply circuit | JohnDG | General Electronics Discussion | 2 | 06-25-2009 11:34 AM |
| Power supply died on Mini Mill | PBMW | Haas Mills | 14 | 03-02-2006 12:51 PM |
| Mini-Mill Power supply case | hargray2 | Benchtop Machines | 3 | 01-24-2006 12:44 PM |
| Power Supply from a computer power supply | jmytyk | General Electronics Discussion | 21 | 01-11-2006 03:56 PM |
