Old 07-02-2009, 05:58 PM
cherokeechief79 is on a distinguished road
haas intuative programming question
we have several newer haas machines at my new shop.2 toolroom lathes and a couple of vertical mills.i was told that the newer intuative programs will directly accept a dxf file from a disc to add toolpath right at the control.i took a small crash course on the intuative about a yr ago for a tl-2.this was never mentioned.how can i tell if these machines will accept a dxf file?
Old 07-03-2009, 10:07 PM
Delw is on a distinguished road
The way I understand it is it has to be a machine that was made in the last month or 2, or has had a software update in the last 3 months. I forget the version number of the software for that dxf addition/[art.
We got a brand new ss and we are 1 version out of that software. I was going to try to see if I could get a software update for it in the next few weeks. Probably not but it would be worth a try.
I know I would more than like never use it cause I have never found a dxf file that was worth a crap unless I made it, and if I make a dxf I might as well make the cam program on the pc also.
I would never trust anyone elses DXF file or program on my machine, unless they wrote me a certified check for the machine cost
Delw
Need Help!- Haas lathe programming question machinistpaul Haas Lathes 10 05-21-2009 08:41 AM
haas mill programming question prupp G-Code Programing 3 03-26-2009 09:03 AM
haas lathe programming question pavelbure Haas Lathes 4 06-17-2007 10:17 AM
Haas mill multiple vise question (programming) joesimmers Haas Mills 14 03-29-2007 05:48 AM
Haas Mini Mill Programming Question CuttingTools Haas Mills 41 05-24-2006 08:44 AM
