Old 06-30-2009, 09:16 AM
CTHaas is on a distinguished road
VF2SSYT X Axis way covers failing
Hope some of you can help with a problem I am having on my Haas VF2SSYT machines. I currently have 11 of these machines and 6 of them had failing X axis way covers. They range from 6 months to 3 years old, all with the same options. Haas tells me that we are the only ones in the world with this problem. I was wondering if anybody out there is having any of the same issues?
Old 06-30-2009, 09:29 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
In what way are they failing? The seals? Bending? If you are having so many failures, I'd have to wonder if it's coolant related (eating the seals), the material you're dealing with (cast iron, graphite or?), or even an operator that leans on the covers during loading and unloading.
I'm not saying any of those are true; just some guesses without more information.
Greg
Old 06-30-2009, 10:50 AM
All of our mills have a 2 axis twin spindle indexer which has us rapiding to an X machine position of -29.000 for a safe tool change position. Also we machine small titanium and stainless parts with a oil based coolant (approved by Haas). Now for the covers and where they are failing is two different spots. The first is the tiny little L shaped bracket that supports the end of the cover. This bracket will crack and cause the cover to flex(bind) and not collapse and expand properly. The second place is the tackwelds are coming apart that hold the shoulders together on each section. These shoulders keep each section from coming apart from one another when expanding and collapsing.
Old 06-30-2009, 03:49 PM
rlabonte18 is on a distinguished road
we have 13 Haas machines ranging from 1992 to 2009 and I have never had an x axis way cover problem just an occasional z cover problem. I would guess your problem maybe be coolant related?
Old 06-30-2009, 04:12 PM
Originally Posted by CTHaas View Post
...... rapiding to an X machine position of -29.000 for a safe tool change position. .....
..... where they are failing is two different spots. The first is the tiny little L shaped bracket that supports the end of the cover. This bracket will crack and cause the cover to flex(bind) and not collapse and expand properly. The second place is the tackwelds are coming apart that hold the shoulders together on each section. These shoulders keep each section from coming apart from one another when expanding and collapsing.
I think it is your frequent rapids to X-29.0000; and I guess you also rapid back.
Every time you do this move the way covers are fully extended at a full rapid, I think the shock loading is fatigung the stainless steel. I know on my VF2s with only 1000ipm rapids you can hear the clang as each section of the telescoped covers is hit by the shoulder of the adjacent one and starts moving.
I would try two things:
Slow down the X axis rapids to reduce the shock loading; which will increase the tool change time by quite a bit even if you only did it to the X.
Alternatively:
Get funky. Calibrate where the X axis is when each shoulder makes contact to start moving the next cover section; rapid to just before that then drop down to a fast feed for the distance needed to let the scetions make contact then go back to a rapid. This will reduce the impact but not seriously increase the toolchange time
Old 06-30-2009, 04:36 PM
omy005 is on a distinguished road
You are not alone, We have 2 VF2SS machines (about 3 years old) with TR160 trunnions on them, so for each tool change the table has to move to the extents of each axis. We have had the X & Y axis way cover fail several times between the two machines. Each time we have just replaced them and crossed our fingers. HAAS doesn't seem to have a solution for this problem.
I don't know why they would say no-one else is experiencing the same problems when the inventory list would show VF2SS way covers being bought. And our HFO has requested information from the factory about it.
Andrew.
VF3+TRT210, VF3, VF2+HRT160, VF2SS+TR160, VF2SS+TR160, VF5TR, VF5TR, VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS
Old 07-01-2009, 06:09 AM
Andrew,
What kind of coolant are you using? Is it water or oil based?
CJ
Old 07-01-2009, 05:55 PM
Andrew,
CJ
It is a water based soluable oil cooant (FUCHS ecocool 420) mix at 5%.
Adnrew.
Old 07-04-2009, 01:00 PM
kojack is on a distinguished road
I move my table to 40 , 0 away to change tools also ....
But I have never used Rapids over 50 % ...
It just seems like a 800lb rotary or trunnion isn't smart to have it
moving around @ 700 imp ..
Old 07-04-2009, 01:32 PM
Well, I haven't had my way covers off yet, but the clanging-together theory seems reasonable. Can foam or rubber bumpers be glued in, under the covers? If you just take the spike off of that instantaneous 'clank', they'd probably stop failing.
Greg
  #11   Ban this user!
Old 07-05-2009, 01:35 AM
Delw is on a distinguished road
I've only had my vf2ss a few weeks and man that machine clanks bad. the rest of the machine is quiet but those covers are pretty darn loud.
I havent taken them off either I am wondering if a spring would help them like they have on fadals?
Delw
  #12   Ban this user!
Old 07-05-2009, 08:43 AM
This would probably help but there is not a lot of room between the sections when the table is at either limit so you would not be able to put in much cushioning. Also I suspect your cushions would just chew up and disintegrate.
3 axis CNC Gantry Mill, or CNC Router Frame, Ballscrews, Linear Rails, Covers, Etc. qualitymachine EBAY ADS 4 06-02-2009 10:02 AM
Need Help!- Profiling program failing Turk88 Haas Lathes 11 04-21-2009 10:37 AM
Please help! Z-axis transistor keeps failing when I turn spindle on jderou Bridgeport and Hardinge Mills 1 03-27-2009 07:09 AM
Need Help!- vf3 way covers mls Haas Mills 2 02-03-2009 07:41 AM
Is our education system failing us in the USA? CJL5585 CNCzone Club House 42 02-26-2007 09:06 AM
