Old 06-27-2009, 09:51 AM
steedspeed is on a distinguished road
Thru spindle coolant won't work.
Hi
I just bought a Haas VF2 1998 with Through spindle coolant but it won't work.
Is there a procedure to prime the system or anything like that?
Old 06-27-2009, 10:52 AM
ltmquik's Avatar
ltmquik is on a distinguished road
BY not "working" what do you mean? Is the pump motor starting? If so, is the motor turning the correct direction? If the motor is turning the wrong direction then your power is phased wrong. I know that on the newer machines there is a series of led's that indicate proper phasing. This is located near the incomming power connections.
If the pump is not starting you need to check that it is connected properly and if it is check the voltage at that point. There should be a breaker in the panel for the spindle coolant pump.
I hope that some of this helps.
Jeff Lange
Lightning Tool & Manufacturing, Inc.
Old 06-27-2009, 11:28 AM
I've been running the machine for about 5 weeks and everything else works fine. The pump turns on but no coolant to the spindle.
Old 06-27-2009, 11:39 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
You said 'the pump' turns on. Don't TSC machines have two pumps?
Greg
Old 06-27-2009, 11:48 AM
Yes, both pumps run and the main coolant is working well but the tsc isn't coming through.
Old 06-27-2009, 01:13 PM
Delw is on a distinguished road
do you have the through collant retention knobs in the toolholders that your using?
the retention knob with the hole through it?
Sorry if this sounds silly but I have done that a few times when setting up new tools
Old 06-28-2009, 12:55 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Check your Retention Knobs first then without a tool in the spindle turn the TSC on for a few seconds to see if it works. Just remember to close the door so you don't take a bath in coolant.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 06-28-2009, 03:02 AM
Superman's Avatar
Superman is on a distinguished road
Some machines have an additional fine filter system for thru coolant, check to see if no-one has turned valves OFF, stopping the flow thru the filter system
Old 06-28-2009, 09:54 AM
I think mine has that. Its a can with a gauge on it.
Old 06-29-2009, 05:25 AM
JoBwan's Avatar
JoBwan is on a distinguished road
Quick check for phasing
Have your electrician change 2 of the 3 leads to change the phasing and see if the pump will then pump fluid. I have seen that the phasing indicators do not always work properly. That pump should be the only thing on the machine that needs determination of the correct phasing. Hope this helps!
Just a good ol' boy, never meanin' no harm.
Joe
Problem- Through spindle coolant makingchips Haas Mills 5 02-07-2009 07:16 PM
Coolant for HF Spindle ? Greolt DIY-CNC Router Table Machines 0 07-03-2008 04:59 PM
Silicon Sealant work with coolant?? Rodm1954 Benchtop Machines 5 11-03-2007 03:15 AM
Does Enco brand coolant work alright? phantomcow2 General Metalwork Discussion 0 12-02-2005 06:41 PM
Spindle coolant what are you using? carbidecraters Fadal 2 04-18-2005 08:43 AM
