Hi I just got a 2002 used mini mill (haas) it was supposed to have rigid tapping and it does not. The previous owner had a new board put in and now i bought it and it does not have rigid tapping.I had to get the code to turn on the floppy drive but they said that this machine does not have rigid tapping turned on.I called the guy I got it off of he is sending me the Invoice for machine purchase but that does not say what options were just a price for all options he got is as a demo machine. Anyway is there any way I can tap with this without spending another $1000 mabey a floating head setup (if I find one real cheap ebay) and what would the program look like machine wont let me us G84 Thanks Mike |
| I have a Tapmatic head I have never used. It's the NCR50 and goes for $933.00 at KBC Tools. I'd part with it for $400 It can run up to 1/2" and 2500 rpm and the reversing ratio is 1:1, unlike a lot of tapping heads. Mine has a 1" straght shank. These heads are known to run into the hundreds of thousands of holes before even being serviced. www.kbctools.com, page 138, p/n #1-415-36625 |
| Did you get the original manual? It will, should, might (?) have print outs of all the Parameters in the back near the Index and often the codes for options are written on these.
Rigid Tapping is the way to go. I tap lots of small 3mm X .5 holes in 6061T6 Aluminum and the rigid tapping option makes it a breeze. I also use form taps and after a thousand or more holes haven't broken a tap. The budget pain of turning on the option may hurt a little bit but getting good tapped holes on a regular basis is really nice. Just some thoughts from a newbie. John |
#10
| Did you absolutely rule out that the rigid tapping was not already paid for? If it had a software reload, they may have just forgotten to re-enable it. As was posted before, a call to Haas should clear that up. And secondarily, just spring for the rigid tapping if you don't already have it. On a mill, it's just too important and versatile. I didn't get it on my lathe because I was stretching to afford it, but I'll probably still crack one of these days and pay for it. The logic for me is: on a TL-1, you can only have one tapped hole per part, but on a mill, you can have unlimited tapped holes. It would be a no-brainer choice on a mill. Even on the lathe, I haven't come up with a reasonable solution, though the tap-matic might be a good work around (though not really cheaper).
__________________ Greg |
#12
I don't know if HAAS offered that option on your particular Year/Model but on the newer machines they offer a 200 hour trial period for rigid tapping and other options. It the previous owner never used the trial period it may still be available. Another tip is to turn it off (the option) when not using the rigid tap and you can save the 200 hours and only use it when you need it. My rigid tapping parameter had 3 options: 0= Disabled (turned off) 1= Option paid for and turned on T= Utilizing the 200 hour trial period This might help you while you save up to purchase the option. If you need the procedure to turn it on I am sure someone here can help you with that. Just a thought. John |
| rigid tapping on mini-mill | plastibob | Haas Mills | 3 | 01-05-2009 04:29 PM |
| What exactly is Rigid tapping? Why people always ask does it do rigid tapping? | cjchands | General Metalwork Discussion | 23 | 12-19-2008 08:19 AM |
| Tapping head or rigid tapping | Gregory_C | Syil Products | 2 | 10-18-2008 12:49 AM |
| Rigid tapping on Haas Mini Mill | rrossey | Haas Mills | 16 | 03-15-2008 09:29 PM |
| Rigid tapping or tapping head | wildcat | Industrial Hobbies (Support forum) | 7 | 09-24-2006 12:08 PM |
