Old 06-21-2009, 09:03 PM
kendo is on a distinguished road
probe false trigger
I rapid to within .5" for a Z-probe, then the next line is:
M78 G31 Z.05 F60.
The M78 alarms out if the probe touches something when it shouldn't
but Im getting the alarm even when its not touching anything, before it even starts moving
Its an intermittant problem that came and went a couple times today
It makes me wonder if the contacts in the probe are dirty to the point that its causing this
Old 06-21-2009, 10:36 PM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Probe distance
I have a Renishaw Wireless probe on my HAAS TM-1P.
The instructions in the book and on the screen tell you to get within .4 of the part with the probe. It you are at .5 it may be alarming out due to not touching something within the .4 requirement. This has happened to me on occasion.
If you have the wireless probe you may also want to check the batteries. It will act crazy when the batteries get low.
Just a couple of things you might want to look at.
John
Old 06-22-2009, 12:48 AM
Delw is on a distinguished road
JOhn I belive Kendo wrote the probe macro for that, thats why it will work for him at .500. unless he didnt make some changes somewhere.
http://www.cnczone.com/forums/showthread.php?t=82547
Kendo did you get alarms on your x setting in this thread?
http://www.cnczone.com/forums/showthread.php?t=82547 post number 8 ?
I am going to try that sample you and pit202 posted this week
Delw
Old 06-22-2009, 06:20 AM
John, Delw is right, Im using my own custom routine so Its set to do what I want
Delw, I was running another macro when this alarm problem popped up yesterday
My center probing macro from the other thread always runs fine when I use it, but so did my Z probing macro up until yesterday
I switched back to the renishaw Z-probe just to make sure it wasn't something with my macro, but I got "probe open" alarm when I did that
This morning, I come in and push the button and all macros run fine with no false triggers again
Old 06-22-2009, 12:29 PM
Kendo, I dont know much about probes or the marcos and wont pretend to however, I notice that when the techs made some change's in some of the parameters that they would power the machine down and power it back on. could it be the same deal you need to power off reboot(power on) for them to take effect?
did you power off yesterday after making your changes? if not maybe thats what happened today you powered off yesterday when you were done then this morning came in powered up and the system then reconized the changes you made ???
Delw
Old 06-22-2009, 12:44 PM
I didnt make any changes
I was running a custom Z-probe macro thats been running on this machine without incident for over 6 months
It started this intermittant false trigger out of the blue and it makes me think the probe might be in need of some TLC
The environment the machine lives in is quite nasty, and its a gantry router with the tool changer hanging out in the open
Old 06-22-2009, 12:53 PM
Haas_Apps is on a distinguished road
Dwell
Put a short dwell before this. Maybe G4 P.5
M78 G31 Z.05 F60.
Old 06-22-2009, 01:08 PM
uhh, ok
should I put dwells everywhere there's a transition from rapid to feed-till-skip?
You've got me wonderin whats going on with this...
is the motion stop at the end of the rapid causing the stylus to rebound?
Old 06-22-2009, 05:23 PM
omy005 is on a distinguished road
Smile
Any time we get a problem with a probe (probe open alarm) program that has been running OK before hand we change the batteries. The only other problem we had once was with the power supply to the Renishaw control unit in the cabinet.
Andrew.
VF3+TRT210, VF3, VF2+HRT160, VF2SS+TR160, VF2SS+TR160, VF5TR, VF5TR, VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS
Old 06-23-2009, 03:37 PM
Mode change
If I get you right - you rapid, then feed 'til skip. On the Haas a mode change will cause exact stop. This brief stop may just shake the probe enough to cause a trigger. If this is the cause a short dwell should resolve it. I said to use a 1/2 second dwell but you may be able to go a 1/4 dwell.
This is just a shot in the dark based on what you had said.
uhh, ok
  #11   Ban this user!
Old 06-24-2009, 07:23 PM
gpcoe is on a distinguished road
If default smoothness is set to finish, this can make an open probe alarm in z measurements. It happened to me once between jobs and the probe would fully calibrate and measure in any axis but z. Worth a shot. I'd say the dwell is a good move, but since you said that this happens even with the haas macro, I'd lean toward the smoothness setting. I don't know what # it is, but it's next to setting 85 "max corner rounding".
Greg
  #12   Ban this user!
Old 07-02-2009, 06:58 PM
Cory is on a distinguished road
I'm having this same problem.
I just sat down and wrote my very first "custom" probe cycle, since I got tired of jogging the probe into position and manually executing the probing cycles.
My code is as follows, for measuring a bore:
T20 M06
G54 X0. Y0.
G43 H20 Z1.0
G65 P9832
G65 P9810 Z-1.375 F100.
G65 P9814 D0.750 S54
G65 P9810 Z1.0
G65 P9833
G28 G91 Z0.
It gets through the first 4 lines ok, then on the 5th it alarms out telling me it's path is obstructed, when it's clearly come nowhere near any kind of obstacles.
Kendo, did you ever figure out how to resolve your problem?
21-M false encoder readings in MPG mode meadowtech Fanuc 3 03-12-2009 03:11 PM
Limit swtich false trigger HakBot Benchtop Machines 18 10-04-2008 01:01 AM
E-stop false triggers Mooser Xylotex 3 12-16-2007 09:52 AM
False Signal From Proximity Detector Geof Haas Mills 7 07-17-2006 03:01 PM
Enable = False while doing other stuff? murphy625 CamSoft Products 7 03-30-2005 12:48 PM
