Old 06-09-2009, 09:48 AM
Croftfoot is on a distinguished road
4th Axis Oil
Hi guys,
I'm new to the forums and have been having a look around but could not find out what the oil spec is that Haas use in the rotary 4th axis, anyone know? as they don't seem to tell you in the manuals.
Cheers guys
Old 06-09-2009, 10:23 AM
FUN4ME is on a distinguished road
Mobil Synthetic gear lube
Old 06-09-2009, 03:24 PM
extanker59's Avatar
extanker59 is on a distinguished road
This is from the Rotary manual on-line at Haas:
"To add oil to the Rotary Indexer, remove pipe plug from oil fi ll port. This is
located on the top plate. Add Mobil SHC-634 (HRT210SHS uses mobil SHC-
626) oil until proper level is reached. Replace the fi ll port bolt and tighten."
Old 06-10-2009, 02:39 AM
Thumbs up
Thanks very much guys, the info is much appreciated.
Croftfoot
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 01:54 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 12:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
