Results 1 to 4 of 4
Thread: Breaker size?
    Jan 2007
    Breaker size?
    vf2ss with 4th axis.
    My salesmen says a 100 amp breaker, thats #1 wire. is that correct on the breaker size?
    After owning probally 10 + machines and installing over 50 before I started my own place I never used more than a 75 amp breaker and on small machines 40-20 and under with 4ths and 5ths never over a 50amp.
    so are they trying to figure out that I have at least a 100 amp panel or do I really need a 100 amp breaker to the haas disconect box?
    I searched the forum and couldnt find any info looking under breaker.
    Delw
    Jul 2005
    He is out to lunch, 50 is enough and in fact you can run a VF2 on a 40 amp breaker but that is getting close.
    Jan 2007
    I just found the tech page on the haas website, there pretty serious, i think its an over kill but ok. I had my chart wrong ( the one in my head ) about the #1 wire its actually #3 for up to 100 amps but #3 isnt common so #2 should be used, however #4 goes to 95 amps on thhn.
    http://www.haascnc.com/pdf/ES0332.pdf
    for a min I was thinking there goes my Ac in the shop this summer, that would suck big time.
    Registered Kool Parts's Avatar
    Jan 2004
    He is out to lunch
    Out to a martini lunch for sure. I have seen a 40 amp work for years.
    Gary
  1. TL-1 breaker size
    By hercules in forum Haas Lathes
    Last Post: 04-11-2009, 01:26 PM
  2. VF-2ss coolant breaker
    By extanker59 in forum Haas Mills
    Last Post: 10-22-2008, 11:18 AM
  3. velocity control unit breaker off
    By scr in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 07-15-2007, 09:18 AM
  4. Circuit breaker trips out?
    By Splint in forum General Electronics Discussion
    Last Post: 12-11-2005, 10:24 AM
  5. Bit breaker
    By CNCadmin in forum Mach Mill
    Last Post: 11-22-2005, 07:33 AM
