Im having a problem with variables that end up with a value like .50003 when I expect it to have just .5 Im probing a part telling it to travel .5" until skip signal but if the surface is too far away, The program needs to know this the best way I've come up with so far is: take the difference between the start point and the end point, if the difference is exactly .5", then the probe didnt touch anything but when this value ends up .50003, it ruins my process so when I command: G31 X-.5 F4. and the probe touches nothing, comes to a stop, and computes the difference why would it be anything but exactly .5" ?????? do I need to round all my start end end points to 4 decimal places before the computation? If this is happening for some random reason, then whats to keep it from rounding up when it should round down one of these days? |
| OK, the Macros chapter of the HAAS manual has this to say: ![]() Doesn't help me much, Im not too keen on exactly why storing from decimal to binary and back to decimal causes this to happen The example uses no decimal point But I use the decimal point when declaring all my variables It doesn't say wether using or not using the point has any affect though so I guess this means if you assign #100 = 7.123456 it could later be read as 7.123457 right? |
| not many of you messing with this kind of stuff I guess that or my rantings are just too elementary for you guys to bother heres another one: Is there some variable inside the control that reflects the status of the probe?when the probe comes to a stop, has the stylus made contact or not? Id think there would be a variable that switched from 0 to 1 just like the little light on the probe that goes from green to red when contact is made so far, like I said, the only way for me to know this is to compare the distance traveled to the distance commanded by the G31 line. This takes me 5lines of code to accomplish at my current level of expertise it looks like this: #113= #5041 (SAVE START POSITION) G31 X - #6 F#106 (ATTEMPT PROBE TOUCH) #114= ABS[ #113 - #5061 ] (FIND THE DIFFERENCE BETWEEN START AND END POINTS) #115= #114 - #6 (SUBTRACT COMPUTED DIFFERENCE FROM COMMANDED TRAVEL DISTANCE) IF [ ABS[ #115 ] GT 0.001 ] GOTO7 (ALARM IF VARIANCE BETWEEN COMMANDED DISTANCE AND ACTUAL DISTANCE IS GREATER THAN .001") #3000= 22 (START POINT NOT WITHIN PROBE REACH) N7 |
| Keep it coming, I am reading just have no answers cause this macro probing stuff is pretty cool. I been doing cncs from the mid 80s and just now starting on macros, Once my haas gets here next week I will be playing alot because I have an extra spindle to do it on. I am sure once it shows up with the probe and I start using it I am going to have a million questions. |
| Kendo, like Delw, I'm just reading and trying to learn. I don't use all the macro programming the probe and machine can use. I just use the already written macros to probe my part. Like the one below that probes the center of an rectangle with cut outs along the centerlines (so I have to move off center to probe). N25 (PROBE) T25 M06 G00 G90 G59 X-1.44 Y0 M05 G43 H25 Z3. T23 G65 P9832 (TURN PROBE ON) G65 P9810 Z.25 F50. (PROTECTED MOVE) G65 P9023 A4. Y3.45 S59. Z-.5 (PROBE Y WEB) G65 P9832 G65 P9810 X0 Y-1.425 F50. G65 P9023 A4. X3.5 S59. Z-.5 (PROBE X WEB) G65 P9832 G65 P9810 X0 Y0 F50. G65 P9023 A9. S59. (PROBE Z LEVEL) G00 Z3. G53 Y0 Z0 M01 Not to your level but maybe someone else can build on it. You're going much deeper than that. But keep it coming. Just reading and learning. |
| Matt, Im using the skip signal, just not as effectively as I'd like G31 X-.5 F#107 will push .5" in negative X until the probe touches M78 G31 X-.5 F#107 will do the same thing, but will throw up an alarm if the probe does touch its used for when you don't expect to touch anything unless somethings gone wrong M79 G31 X-.5 F#107 will throw up an alarm if the probe doesn't touch, to let you know somethings wrong if it didn't the problem is, I need this check to occur without any alarms I just need the program to make a decision based on wether it touched or not Im getting this accomplished just fine with my 5 lines of code, it just seems too sloppy if you look at pit202's macro in the "reproducing an irregular shape" thread he's using variable #1029 which is a discrete input that his homemade probe puts out telling wether the stylus is deflected or not that would be very useful to me if the Hass/Renishaw combo had something like that but I dont think it does. At least I can't find anything like it when scanning through the renishaw macros that came with the probe. Everywhere theres a G31 line in those macros, theres a bunch of math going on before and after the move a lot like my code above, which compares the commanded distance to the actual distance traveled in order to find out if the probe touched or not. |
| extanker, heres my center probing macro instead of starting at the center and then returning to the center after each touch, mine goes around the part from one side to the next and saves time. It will always probe the front of the part first, then right, back, and left It requires G154 P98 and P99 to be empty for use in the calculations, but that could be changed If you dont want to probe the part at the actual center, you can offset where it touches at by as much as 1" in either direction in the Y or X X offset is I-word Y offset is J-word you can increase the offset, but theres an alarm in my macro keeping me from doing it accidentally, just change the value the alarm checks for the only offsets you can update with this are G54 through G59 you may wish to add some more protected moves in there, like for the rapid moves between sides, and the Z moves in the G43 lines at least untill you get confident with it, give yourself a big retract amount and make sure the probe is at a clearance height before calling the macro hope this helps you guys learn some more ask me anything, I like to help if I can Code: % O09009 (NEW CENTER PROBE) (PROBES THE CENTER AND UPDATES SPECIFIED OFFSET) (SAVES X AND Y MEASUREMENTS TO #600 AND #601) (**MACRO CALL**) (G65 P9009 A2. X15.38 Y33.43 J-1. Z-0.15 S56 R4.) (A = 1 FOR BLOCK, 2 FOR POCKET) (X = OVERALL X WIDTH) (Y = OVERALL Y WIDTH) (I = DISTANCE TO OFFSET FROM CENTER IN X) (J = DISTANCE TO OFFSET FROM CENTER IN Y) (Z = PROBE DEPTH) (S = OFFSET TO BE UPDATED) (R = RETRACT DISTANCE) (INITIALISE VARIABLES) #19= ROUND[ #19 ] #24= ABS[ #24 / 2 ] #25= ABS[ #25 / 2 ] IF [ #18 EQ #0 ] THEN #18= #5003 IF [ #19 EQ #0 ] THEN #19= 54 #18= ABS[ #18 ] IF [ #4 EQ #0 ] THEN #4= 0 IF [ #5 EQ #0 ] THEN #5= 0 (ALARM CONDITIONS) IF [ [ ABS[ #4 ] LE 1 ] OR [ ABS[ #5 ] LE 1 ] ] GOTO5 #3000= 1 (I OR J MUST BE BETWEEN -1 AND 1) N5 IF [ #18 GE 0.25 ] GOTO10 #3000= 2 (RETRACT MUST BE GREATER THAN .25) N10 IF [ #25 NE #0 ] GOTO20 #3000= 3 (NO Y VALUE) N20 IF [ #24 NE #0 ] GOTO30 #3000= 4 (NO X VALUE) N30 IF [ #26 NE #0 ] GOTO40 #3000= 5 (NO PROBE DEPTH) N40 IF [ [ #1 EQ 1 ] OR [ #1 EQ 2 ] ] GOTO50 #3000= 6 (INPUT "A1" FOR BLOCK "A2" FOR POCKET) N50 IF [ #26 GT - 0.5 ] GOTO60 #3000= 7 (PROBE DEPTH SHALL NOT EXCEED Z-.5) N60 (IDENTIFY AND ASSIGN WORK OFFSET BETWEEN G54 AND G59) IF [ #19 NE 54 ] GOTO100 #101= 5221 #102= 5222 #103= 5223 GOTO700 N100 IF [ #19 NE 55 ] GOTO200 #101= 5241 #102= 5242 #103= 5243 GOTO700 N200 IF [ #19 NE 56 ] GOTO300 #101= 5261 #102= 5262 #103= 5263 GOTO700 N300 IF [ #19 NE 57 ] GOTO400 #101= 5281 #102= 5282 #103= 5283 GOTO700 N400 IF [ #17 NE 58 ] GOTO500 #101= 5301 #102= 5302 #103= 5303 GOTO700 N500 IF [ #17 NE 59 ] GOTO600 #101= 5321 #102= 5322 #103= 5323 GOTO700 N600 #3000= 6 (USE OFFSETS G54 THROUGH G59) N700 (CHECK BLOCK OR POCKET) IF [ #1 NE 1 ] GOTO710 #110= -0.5 #111= 0.5 GOTO810 N710 #110= 0.5 #111= -0.5 N810 (APPROACH GAP) #105= #24 + #4 #106= #25 - #5 #107= #24 - #4 #108= #25 + #5 (P99) #15961= #[ #101 ] - #24 #15962= #[ #102 ] - #25 #15963= #[ #103 ] (P98) #15941= #[ #101 ] + #24 #15942= #[ #102 ] + #25 #15943= #[ #103 ] (MAIN CODE) G00 G90 G154 P99 X#105 Y#110 G43 H18 Z [ #26 + 0.5 ] M78 G31 Z#26 F60. G65 P9811 Y0 S154.99 G00 Z#18 G90 G154 P98 X#111 Y - #106 G43 H18 Z [ #26 + 0.5 ] M78 G31 Z#26 F60. G65 P9811 X0 S154.98 G00 Z#18 G90 G154 P98 X - #107 Y#111 G43 H18 Z [ #26 + 0.5 ] M78 G31 Z#26 F60. G65 P9811 Y0 S154.98 G00 Z#18 G90 G154 P99 X#110 Y#108 G43 H18 Z [ #26 + 0.5 ] M78 G31 Z#26 F60. G65 P9811 X0 S154.99 G00 Z#18 (RESET CENTER FOR SPECIFIED WORK OFFSET) #[ #101 ]= [ [ #15961 - #15941 ] / 2 ] + #15941 #[ #102 ]= [ [ #15962 - #15942 ] / 2 ] + #15942 (SAVE X Y DIMENSIONS) #600= ABS[ #15961 - #15941 ] (X MEASUREMENT) #601= ABS[ #15962 - #15942 ] (Y MEASUREMENT) M99 % |
| macros | georgebarr | Mach Mill | 1 | 06-03-2009 08:11 AM |
| Need Help!- X3 CNC macros | trainfred | Syil Products | 6 | 05-20-2008 07:42 PM |
| Need Help!- help with macros | gj83 | General CNC (Mill and Lathe) Control Software (NC) | 2 | 04-11-2008 08:42 PM |
| Need Help!- macros | bob@apc | Mazak, Mitsubishi, Mazatrol | 2 | 02-04-2008 11:42 AM |
| Macros | cncfreak | General CAM Discussion | 24 | 05-06-2005 05:04 PM |
