Old 05-14-2009, 04:19 PM
panaceabea is on a distinguished road
G81 RETRACT HIEGHT?
Not sure what setting I have changed but now when running a g81 or g83 file the head retracts to the z home position between each hole drilled. What do i need to change?
Old 05-14-2009, 04:27 PM
All the way to machine home?
The codes and Settings that are involved in the retraction for canned cycles are:
G98 Initial Point Return so it comes back to the Z position immediately before the canned cycle.
G99 R Plane Return so it comes out to whatever your are value is.
Setting 22 Canned Cycle Delta Z controls G73 retraction but I have no idea if it affects other drilling or boring canned cycles.
Setting 52 G83 Retract Above R but I don't know if this affects G81.
Help needed Mazatrol M+ tool hieght mt92 Mazak, Mitsubishi, Mazatrol 5 03-31-2009 03:19 PM
G76 Questions bore with retract kojack Haas Mills 1 12-20-2008 07:38 PM
retract and feed beartrax Mastercam 3 08-11-2008 10:28 AM
Eia Tool Hieght Offset On Nexus 640 anvil99 Mazak, Mitsubishi, Mazatrol 1 03-22-2007 11:55 PM
Retract Height Sanghera SheetCam 1 05-29-2005 11:52 PM
