Old 05-13-2009, 04:14 PM
weirdharold's Avatar
weirdharold is on a distinguished road
Unhappy Haas Mirror X
Here's a good one for you. We have (3) Haas VF - 4 's. Oldest (2) made in 05 & newest(1) made in 07 . We have parts we make left's & right's & program is written for one side & we mirror X to get the other. The (2) oldest do this with no problem, work's great, but the new one will error out, # 317, Y over travel range & makes really screwey tool-path's in graphic's before it error's out. We have compared setting's in controler's between mill's & can find no difference. Maybe in parameter's but we don't know what we are looking for. You can mirror X & Y & it will work but all that does is rotate's program 180 & not the result's we wan't. We have redone program to fit our need's for now, but would like to fix this. Thank's in advance for any help.
Harold C.
Old 05-13-2009, 04:50 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
I think this is a problem with cutter compensation. If I remember correctly, there is something screwy with mirror and comp direction. Are you using cutter comp in the control?
Greg
Old 05-13-2009, 05:04 PM
Yes Greg, we do use it ,but you can take it out, ( G41 D2 ) & it will still error out with mirror X on. Kinda what I thought. You can run the graphic's & instead of swinging arc's , it look's like it's trying to swing complete circle's. Funny you can run the same program on the other (2) VF-4's with cutter comp & no problem.
Harold C.
Old 05-14-2009, 02:19 PM
pit202 is on a distinguished road
Haas machines have many hidden bugs in software , today I could not move the Z axis on a lathe for incremental 80mm from part zero ( Z overtravel ) but with absolute movements I was able to do it , funny - maybe not so much.
Run a simulation with a programmed AirGun ;-) the airgun goes crazy.
I am very curious if the haas technicans knows about the error with the tool changer ToolMark switch and inverting them on invert screen - without inverting works well , inverted can not count the signals right - and don`t tell me that I can not invert them because of that I get my problems , I know what is a NO and NC switch and what for are inverts for.
mirror image cp465vw Machines running Mach Software 8 04-13-2009 10:39 PM
Mirror - is this a bug? LongRat SheetCam 0 10-11-2007 12:48 PM
Mirror function SWPM Surfcam 1 08-17-2007 04:04 PM
Mirror My Text Plaqn B BobCad-Cam 13 06-03-2007 08:35 PM
Mirror macro goodfella Coding 1 11-29-2006 06:38 AM
