You would be better off with a USB Flash drive. They will handle 2GB no problem. Better than the 1.44mb of a floppy.
| What is the context of your question? Are you replacing and existing floppy drive that does not work? Do you want to install a floppy drive in a machine that came without it?
I may need to replace one that is acting up. I have a micro disk for our Mazak, and that thing has a non standard floppy drive. |
| I watched one being retrofitted to a machine and it looked the same as the ones in older computers. If you already have one installed you don't need the activation code so there should be no problem. Pull the covers off and see if you can find a manufactures name on the floppy unit.
Is it possible to add a USB flash drive to a machine that just has a floppy disk? |
You need to talk to Haas for a definite answer but a couple of years ago I was told it was either/or. The machine software was different in some way and a floppy machine could not run a usb port.
#10
| Since USB came up and you're gonna' be replacing the drive anyway ![]() http://cnczone.com/forums/showthread.php?t=69389
__________________ Greg |
#12
| Slightly off topic but as you mentioned it those non-standard drives for mazaks are on there too for about $20 which beats the price, about $250 I seem to recall, that I was quoted by mazak.
__________________ Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself. Mark Twain |
| Need Help!- DNC from floppy drive | jwknow | Haas Mills | 5 | 03-11-2010 08:39 AM |
| Mitsubishi VX-20 Floppy Drive Help | ltkettch17 | EDM Machines | 2 | 04-28-2009 01:42 PM |
| Floppy Drive | advt001 | Cincinnati CNC | 4 | 10-11-2008 09:35 PM |
| Foolin around with an old floppy drive | compuslave | Stepper Motors and Drives | 9 | 12-15-2007 10:17 AM |
| haas floppy dnc restart | bytecolor | Haas Mills | 6 | 10-19-2006 07:31 AM |
