Results 1 to 9 of 9
Thread: 4th axis wiring questions
    WGJ
    WGJ is offline
    Oct 2008
    I have a TM-3 and am wanting to pc together a 4th axis. I have found a servo amplifier and need to see an example of how the 4th axis integrates into the machine. I guess any vm would help, but I would love to find someone who owns a TM and has the 4th axis wired in. I need pics of the parts/wiring and part numbers of the actual cables. Any help would be greatly appreciated.
    Registered Donkey Hotey's Avatar
    Nov 2007
    I think you have to also have the unlock code (4th axis enable) for the control, so even if you get through all of that, it won't work.
    If you have the amplifier, the only missing piece is the cable from the amplifier to the side of the cabinet. Power and logic control are the same as you see on the other axis amplifiers. Power just jumps from one to the next if I remember correctly.
    Greg
    Dec 2008
    I think on our TM you can just turn the 4th axis on.
    Nov 2007
    Doh! Wrong thread.
    Greg
    Nov 2008
    canada
    tm3
    just finished wat ur doing with 4th axis HA5C indexer on TM3 can take pics if u want
    Registered HelicopterJohn's Avatar
    Dec 2005
    Seffner, Florida USA
    Pictures
    Please post pictures of your project.
    John
    WGJ
    WGJ is offline
    Oct 2008
    Absolutely I want to see pics. And did you need a code to unlock 4th axis or was it just a setting that needed to be turned on? Thanks.
    Dec 2008
    Quote Originally Posted by WGJ View Post
    I have been through all of my settings several times in the last month and I am 99% sure it is just a setting to enable 4th axis.
    Tim
    Jul 2005
    POLAND
    you have 99% right :-) in settings you can turn the 4th axis BUT indexing axis , not one , you can have more
    1. More questions on wiring. :)
      By bkboggy in forum DIY CNC Router Table Machines
      Last Post: 04-10-2009, 12:12 AM
    2. Questions about wiring
      By Phife in forum General Electronics Discussion
      Last Post: 04-05-2009, 02:40 AM
    3. New Machine Build- Gecko 540 wiring: Questions
      By SpeedsCustom in forum Gecko Drives
      Last Post: 09-28-2008, 12:52 PM
    4. Wiring Breakout Board Questions
      By Dingo745 in forum Xylotex
      Last Post: 03-31-2008, 03:47 PM
    5. Wiring Questions
      By cnc2k in forum General Electronics Discussion
      Last Post: 11-27-2004, 06:45 PM
