Old 04-30-2009, 08:23 AM
pit202 is on a distinguished road
changing the programmable coolant from macro
Hi All ,
is there a way to change the coolant position in the tool offsets from a macro ( eg. #50xx ) ? My goal is to write a macro that pre-set the coolant nozzle after tool messure.
__
Peter
Old 04-30-2009, 08:28 AM
kendo is on a distinguished road
you can definately do that,
I was planning on doing the same thing sometime soon
the variables for tools 1-200 are #3401-#3600
Old 04-30-2009, 08:47 AM
oh, I didn`t saw this in my old manual , thanks !
Old 05-04-2009, 06:58 AM
It works for me , if you want - feel free to use it :-)
__
Peter
File Type: txt spigot.txt‎ (559 Bytes, 52 views)
Old 05-04-2009, 04:07 PM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Macro
Hi Peter,
I have an older 20 position HAAS PCOOL nozzle and also have the Renishaw Wireless Probe and Wireless Toolsetter. My HAAS TM-1P also has Macros. Also, my units of measure are Imperial not Metric.
I am not very familiar with Macros and don't understand how this would be incorporated into my system to get it to work.
Do you have the ability to do a YouTube video or some detailed step by step instructions for a newbie like myself?
Would these lines of code be added to the present 9XXX series of probing programs currently loaded into my HAAS Control?
Any information or assistance you could offer would be appreciated.
Thanks for sharing,
John
Old 05-04-2009, 04:22 PM
there is no need to put a video on YT ;-) ( I have 20 pos. coolant too ) this is a simple linear interpolation software , look at the first lines :
Code:
#10= 66. ( min. tool length )
#11= 8. ( spig. pos. for min. tool )
#12= 185. ( max. tool length )
#13= 15. ( spig. pos. for max. tool )
all you need to do is change those lines , find a shortest tool , messure it and find out which coolant position is the best, the tool length put in #10 value , and spigot position in #11 , do the same with a long tool , and put the values into #12 and #13.
get a code from VQC to messure the tool , after G65 Pxxxx line put
Code:
G00 G90
G65 P9023 A12. T1
G65 P9880 T1       < ----- line added manually
to not writing every time this line I added a line in the O9996 VQC file like this :
Code:
N1301
(TEMPLATE)
(NAME Auto Length Only)
(GCODE)
(T#ToolNo M06)
(G00 G90)
(G65 P9023 A12. T#ToolNo)
(G65 P9880 T#ToolNo)             < ---- here is my line
(M30)
(END GCODE)
hope this works for you.
_
Peter
Old 05-04-2009, 07:16 PM
Marcos
Hi Peter,
I really appreciate you taking the time to give me a more detailed explanation.
I have just verified the shortest and longest tool lengths in my HAAS tool offset register and the associated PCOOL positions. I will replace your numbers with those numbers in your program on lines 10,11,12 & 13 and copy your program into my HAAS Memory. I realize that I will have to unlock the parameters and also allow access to the 9XXX series of programs.
I will then insert your G65 Program call line (G65 9880 T#ToolNo) in each one of the tool setting sub programs just above the (M30) line in the O9996 VQC file.
Does it sound like I am on the right track?
Thanks again for helping out a Macro Newbie!
John
Old 05-05-2009, 12:39 AM
Yes, this is correct. First try if it works, and this method don`t work with sequential and random tool measure - for now I do not know where to put this line to be better.
Old 05-05-2009, 09:41 AM
behindpropeller is on a distinguished road
Pit-
Thanks for posting that. Along with John, I am learning also.
Tim
Old 05-05-2009, 10:05 AM
Many Thanks!
Peter,
You are the man!
I just modified your program to Imperial measurements and tried it out on my HAAS TM-1P.
It works GREAT.
I have only modified the N1301 ( Auto Length Only ) sub program in the Renishaw O0996 program so far for testing purposes.
Really neat as it records that appropriate PCOOL position in the HAAS Tool Register during the Tool Presetting Cycle on the Renishaw Wireless Tool Setter.
Just another GREAT idea from one of the guys here on the CNCZONE that are willing to share there knowledge and expertise with the newbies such as myself.
John
  #11   Ban this user!
Old 05-05-2009, 10:13 AM
No problem John , I make the money when the chips are flying and not when I play with the PCool ;-) I am happy that it works for you.
__
Peter
PCOOL (Programmable Coolant Nozzle) HelicopterJohn Haas Mills 28 11-10-2009 10:59 AM
problem with programmable coolant function stovepipesteve Haas Mills 14 10-14-2009 03:04 PM
Programmable Air/Coolant for HAAS Machines HelicopterJohn Haas Mills 3 04-01-2009 09:29 PM
programmable coolant nozzle jprobst Haas Mills 7 06-27-2008 12:38 PM
programmable coolant pit202 Haas Mills 8 12-21-2006 09:51 AM
