Old 04-28-2009, 01:29 AM
kojack is on a distinguished road
5 axis positioning question
I normally use g54 and cut with tip for Surfaces on a 5 axis table
I was putting some logos on a part the other day
I figured Id program the logo with 3 axis paths and just position the part
So I positioned the part and set my work offset with G58
Figured every time a part needed a logo
I would just use a G58 in the program and it would rotate the A and B axis
It doesnt work that way Unless I call out a A62 B 180
I thought the G58 would turn the rotary's since my offset table The A and B
axis have been set with Part Zero's
What AM i missing ?
Thanks for the help ...
Old 04-28-2009, 05:49 AM
makingchips's Avatar
makingchips is on a distinguished road
Set the A/B the same way you would set the X/Y at the position you need, but there is no way around programming G90 G58 X0. Y0. A0. B0. so in hindsight A62 B 180 is just as easy. You could make a little sub program that can do this with M98 then you only have to program the A62 B 180 program once.You only add the M98 M99 to the program you need logos on.
MC
Old 04-28-2009, 09:31 AM
MC
Thanks for the help ....
I was just confused on why you set A and B in offset table but it doesnt move if you call it out ?
Its not that big a deal I could have programed my part LOL with less typing
so far .. I just figured I was missing something ...
Old 04-28-2009, 11:47 AM
Caue's Avatar
Caue is on a distinguished road
Kojack,
If you loaded A62. B180. into Work Offset Table, as G58 postioning angles, you should only call G0 G58 X## Y## Z## A0 B0 (just as makingchips said) on your code and it should work.
If this is the case, it's programed this way and not working, please post CNC code and we'll analyse it for you.
Cheers!
Old 04-28-2009, 02:24 PM
here are my settings and program
here is a screen shot of the Offset table
here is the code
O0123
(PROGRAM NAME - LOGO )
(DATE=DD-MM-YY - 24-04-09 TIME=HH:MM - 00:02 )
N100 G20
N102 G0 G17 G40 G49 G80 G90
( 1/16 FLAT ENDMILL TOOL - 6 DIA. OFF. - 6 LEN. - 6 DIA. - .0625 )
N104 T6 M6
N106 G0 G90 G58 X.2435 Y-.9587 S12000 M3
N108 G58 H6 Z4.
N112 Z.1
N114 G1 Z-.02 F6.2
N116 X1.7565 F40.
N118 G3 X1.8393 Y-.9387 I-.0065 J.2087
N120 G1 X.1608
N122 G2 X.1271 Y-.9188 I.0893 J.1887
N124 G1 X1.8729
N126 G3 X1.8964 Y-.8988 I-.1229 J.1688
N128 G1 X.1036
N130 G2 X.0858 Y-.8789 I.1464 J.1488
N132 G1 X1.9142
N134 G3 X1.9281 Y-.8589 I-.1642 J.1289
N136 G1 X.0719
N138 G2 X.0612 Y-.839 I.1781 J.1089
Name:	G58 settings.jpg‎
Old 04-28-2009, 03:45 PM
big_mak is on a distinguished road
I can't see you calling A or B in your program. Maybe I'm just missing it!
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 04-28-2009, 03:56 PM
no your right ...
But I have a G58 in there and my G58 has the rotory where i need it too go ..
look @ my G58 on the offset table
I run the normal program with g54
I wanted to just place my logo program with a different offset G58
figured it would rotate the tables ...
Old 04-28-2009, 03:57 PM
G58 will just make that work Coordinate active, it will not reposition until you G00/G01 A## B##
Old 04-28-2009, 04:11 PM
So G58 or G56 wont postion A and B axis unless I call it out
where would you put the B and A move in this Program Can i run it on my
g58 line
I need to go B 208.485 A 62.2
O0123
N100 G20
N104 T6 M6
N108 G58 H6 Z4.
N112 Z.1
N114 G1 Z-.02 F6.2
N116 X1.7565 F40.
N120 G1 X.1608
N124 G1 X1.8729
N128 G1 X.1036
N132 G1 X1.9142
N136 G1 X.0719
Old 04-28-2009, 04:16 PM
Make Line N107 G0 A### B###
  #11   Ban this user!
Old 04-28-2009, 05:19 PM
gpcoe is on a distinguished road
g58 line
O0123
N100 G20
N104 T6 M6
N108 G58 H6 Z4.
N112 Z.1
N114 G1 Z-.02 F6.2
N116 X1.7565 F40.
N120 G1 X.1608
N124 G1 X1.8729
N128 G1 X.1036
N132 G1 X1.9142
N136 G1 X.0719
This is how I would write it:
N106 G0 G90 G58 X.2435 Y-.9587 B208.485 A62.2 S12000 M3
However on your offset page under G58 I would have the Rotary axis set the same as the other (G54) coordinates. Mine are set to the B axis face (the one you mount to) planer to the machine table. So if I were to do work on the horizontal (A90) in any work coordinate I would always call out A90. in the program. That way anyone else who programs for the machine can program the same and setup is straight forward.
Greg
  #12   Ban this user!
Old 04-28-2009, 11:50 PM
Caue's Avatar
Try this way, please
Alright, now we have your original code, it's quite easy. It's correct that inform G58 only load this information to the machine, but it does NOT command any movement. But, once the coordinates (angles) are informed at Work Offset Screen, you must call A0. (tip: you can type only "A" and the software will complete when you type Write/Enter or Insert) B0. The code will be:
O0123
N100 G20
N104 T6 M6
N106 G0 G90 G58 X.2435 Y-.9587 A0. B0. S12000 M3
N108 G43 H6 Z4.
N112 Z.1
My inputs are bold. I use to call all 4 axis positioning at the same block (only exception to Z axis), but you need to check if there's enough space for it at the first time you run the program.
Please, note that I've replaced the second G58 for G43, and this is the most worrying point, cause it may crash the machine.
I hope it can be useful. Once more, thank you all for choosing Haas Automation!!
Rookie Question...3 axis vs 4 axis controller Ferrari2007 DIY-CNC Router Table Machines 3 09-13-2009 08:04 PM
Single Rotary Positioning Axis RLMTS Mechanical Calculations/Engineering Design 6 01-11-2008 12:46 PM
Need help with motorized positioning xshaper Work Fixtures and Hold-Down Solutions 6 11-25-2007 05:38 PM
Bridgeport VMC760/20 Z axis not positioning correctly for tool change seano_78 Bridgeport and Hardinge Mills 5 08-14-2007 03:38 PM
Boss 5 X axis positioning kewl_cat Bridgeport and Hardinge Mills 1 01-07-2006 10:04 AM
