Old 04-27-2009, 02:41 PM
Paul in OK is on a distinguished road
Z axis home position reset
Changed out the Z axis ball screw and nut. Z position is now 0.078 higher than it was before. What's the procedure to change the 0 point?
Paul in OKC
Old 04-27-2009, 05:56 PM
rlabonte18 is on a distinguished road
You will need to change param 64 to line up with the tool changer. I don't believe the zero point is adjustable or makes a differance just change your workshifts.
Old 04-28-2009, 11:54 AM
Caue's Avatar
Caue is on a distinguished road
Zero point is not adjustable by software, cause it depends on the physical zero microswitch position (at least I think it works this way, I'm not from technical assistance department). About adjusting param 64, it's imediatly necessary before you have ATC problems. If you have any doubt about how to do this, please contact us and we could send you the necessary tutorials, it's quite easy to do.
Cheers!
Old 04-30-2009, 05:05 PM
awesome83 is on a distinguished road
You have to adjust the grid offset (par127?) correctly first before setting up your Tool change height (par 64). Otherwise you will get zero-return margin to small or Large alarms.
Old 05-12-2009, 11:10 PM
gerald vern is on a distinguished road
HI I like your helpfull attitude. i have a 2008 TM3 is there any way to refit TSC to my machine.i know i will need to drill the spindle ;could it be done?
Old 05-12-2009, 11:14 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Honestly I would contact the local HFO to do this juts to have piece of mind.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 05-12-2009, 11:27 PM
I think full TSC with a hole through the spindle is serious overkill on a TM machine. An alternate approach which is feasible with low speed spindles is to use a coolant inducer.
Here are two links from a Google search on 'coolant inducer'.
http://www.rotaryunions.net/goldseries.htm
http://www.bigkaiser.com/KPT_PDFs/PG8_19.pdf
Old 05-13-2009, 06:29 PM
You wouldn't have to drill a hole thru the spindle, but you would have to replace the standard drawbar with a TSC drawbar (which would have a hole thru it) and would need to modify or replace the TRP and install the correct sensors and valves, pump, ect. I think that you would be able to enable it in the control so that i would work like a VF machine.
I haven't done this and I haven't heard of anyone needing/wanting tsc on a TM, might be a little messy.
But hope this helps
Old 05-13-2009, 07:48 PM
thanx for the links Geof
Old 05-13-2009, 08:05 PM
But hope this helps
thanx 83 its allready messy ! Im workn on side panels ;arain coat will half to do for now. mostly need it to .375 drill 1.25 AL through hole; custom lite mounts.there an 8in pylon for airo hiway tractor LITEFORCE.must be easyoff.
Home Position Mooser Tormach PCNC 24 03-26-2008 10:30 AM
TL2 Would Not Find Home Position Geof Haas Lathes 6 01-24-2008 09:21 PM
Reset mach 3 after stoping pogram and returning home Prboz Mach Mill 0 12-12-2007 05:05 AM
Z Axis Home Position Problems JMFabrications General Metal Working Machines 3 10-24-2006 10:58 PM
Home switch position MrBean DIY-CNC Router Table Machines 1 12-16-2004 06:00 PM
