Old 04-26-2009, 09:35 AM
US-GUN'S's Avatar
US-GUN'S is on a distinguished road
Haas-VF-0 alarm no voits
I Have a buss DC alarm no volts I would like to know if it in the servo dist pcb
Old 04-26-2009, 10:34 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
What year is this machine? Does it have a Haas branded Vector Drive or a Magnatek / Mistubishi type drive?
Greg
Old 04-29-2009, 06:37 AM
US-GUN'S's Avatar
It is a 94 and Magnatek / Mistubishi drive
Old 04-29-2009, 10:19 AM
I'm not totally familiar with that generation machine but I can talk in generalities:
I think your machine runs on 165V DC buss voltage. That should be present at the high voltage inputs to each axis amplifier. If it's not, then I'd trace it back up the chain. Those wires have to come from some kind of rectifier / power supply box. It should have a very large rectifier (screw terminals) and capacitors in it. It should also have a large relay either inside that box or immediately preceding it. That box and contactor/relay are what I suspect has gone wrong (at least that's what the error suggests).
If you aren't experienced and confident around high voltage, stay away from that stuff. Those capacitors will store very high voltage even after the power is off. They take about 15 minutes to fully discharge. Insert the rest of the lawyer stuff here.
Greg
Old 04-29-2009, 08:27 PM
awesome83 is on a distinguished road
The Servo's have to be on to measure the DC Buss voltage correctly, so there can't be any alarm/e-stop ect.
Old 05-21-2009, 08:17 AM
US-GUN'S's Avatar
It has a alarm 160 If somebody could help me narrow down circuit I should be looking at I would appreciate it
Alarm 157 Haas VF3-SS rshields21 Haas Mills 7 12-09-2011 02:03 AM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
Haas Alarm Problem BMackinnon Haas Mills 24 03-13-2008 12:31 PM
Haas VF2 ALARM 127 &115 grease Haas Mills 2 10-18-2007 03:31 PM
Haas alarm 165? UBRacing Haas Mills 5 07-08-2007 11:43 AM
