Old 04-25-2009, 01:34 PM
RodneyH is on a distinguished road
HAAS Lathe and Mill
I have a 2 part problem- I am looking for a full blown maintenance/REPAIR manual for a SL30 and VF3YT50. My VF3YT50 spindle lock up recently and I need an exploded view for the spindle head/clamp-unclamp cyclinder. Can use the complete manual or a partial. Anything would be a great help. I've been told it was either my spindle bearings or my cylinder adjustment has backed off stalling out the spindle. This machine is 2 years old with very few hours, outside of warrenty and right now its down. I would greatly appreciate any help I can get.
2nd- My SL30 has had issues even before warrenty was up. It has had chatter problems starting about 5 months after purchase and has been worked on (5 or 6) several times. Just prior to the end of the warrenty the machine was worked on the cut beautifully for about 3 weeks before it started messing up again, still under warrenty. Since then the spindle bearings have been changed, machine totally realigned, a #5 taper added to the tail stock, and was going to replace the -x- axis ball screw because of .0002/.0003 backlash. I believe the techs lacked knowledge of there own equipment. The chatter has been blamed on my slab and tooling yet the machine is not working correctly after the tech leave. Blamed on everything but the machine's rigidity. Up till the last time the techs came out the techs work was covered even though it was 3-4 months out side of warrenty but the last time it was not and now I have a machine that still has chatter and a $2300 bill to boot..
Could use some in put on both issues I am having.
Thanks,
Old 04-25-2009, 02:07 PM
djr76's Avatar
djr76 is on a distinguished road
As for the manuals, you have to buy those from Haas for 50$ for the mechanical and another 50$ for the electrical. For the lathe, I would call Haas directly and work with them since it seems your HFO $hit the bed and never fully fixed your machine.
Old 04-25-2009, 02:13 PM
I have done that and talked with several in California too and I get the same from both. Not sure where to go from here....
Old 04-26-2009, 12:28 PM
djr76's Avatar
Tell them you will never buy a machine from them again if they wont come to a reasonable agreement.
Old 04-27-2009, 07:21 AM
I have done that as well and the next purchase was not a Haas.
Old 04-27-2009, 11:19 AM
djr76's Avatar
We had a similar problem with our lathe. We purchased an HL-2 back in 98' and the operator at the time programmed his very first part and had his offsets all fubarred, 100% rapids, 2000 rpm chuck, and turret dont mix well. After a few months of the HFO coming out to keep fixing issues with it, they finally got it totally fixed. A little bit time after that my boss wanted to trade the machine in for the newer SL machines but the HFO/Haas wouldnt give him a fair trade in value. He vowed to never buy a Haas lathe again and now the HFO salesmen dont even ask anymore.
Old 04-27-2009, 03:02 PM
Hmmm, That sounds fimilar. I get a email ever so often from my Haas rep but its bulk email. There hasn't been a Haas rep inside my door since November of 2008. I don't believe they care to resovle this issue and truly don't know if they know how to resovle it.
Old 04-28-2009, 11:15 AM
djr76's Avatar
Maybe look into see if some kinda lemon law might be in effect.
Old 04-29-2009, 09:09 AM
gepperta is on a distinguished road
You just can't hog steel on a Haas machine, lathe or mill. That's my experience with them. They are not solid construction, they don't even scrape the column to base fit on the mill, so they are prone to vibration.
Old 04-29-2009, 11:13 AM
bearman22 is on a distinguished road
I also have many problems with chatter on my sl30 lathe. I have come to the conclusion that the machine is just not rigid enough. Let me know if u or any one else can solve this problem.
  #11   Ban this user!
Old 04-29-2009, 11:14 AM
djr76's Avatar
Guess you've never seen the nickel test done on a haas.
  #12   Ban this user!
Old 04-29-2009, 12:29 PM
No, sure haven't. What is this test about?
Haas Lathe Manual? J5P332 Haas Lathes 2 08-05-2008 01:15 AM
?????HAAS CNC LATHE????????? JROM Haas Lathes 4 06-04-2008 12:51 PM
HAAS SL20 Lathe SGP Haas Mills 33 01-04-2007 04:06 PM
haas lathe post rbest27 Surfcam 1 12-22-2006 08:52 AM
HAAS mini lathe marto74 Haas Lathes 4 01-15-2004 11:55 AM
