I have run the very simple string below thousands of times on my milltronics and bridgeport with zero problems and somewhere around 150-160 times on the new HAAS but for some reason a few minutes ago the HAAS just decided to skip the tool change from T15 , a center drill to T30 which is a 3/32 drill bit thats aprox 2" longer than the center drill. Machine didnt change tools and as a result destroyed 10 parts with the tool holder and damaged my fixture. The fixture is repairable and the damaged parts only set me back a little over $500 , my main concern is why would the machine have skipped a tool change ? I want to have confidence that I can leave it to run un attended for long periods . Parts lost today were cheap , but I do on occasion machine injection molding dies that run 40+ hours machine time that I cant so easily afford to scrap. What might have caused the machine to ignore the tool change ? G57 (MOVE BACK TO TOP TO DRILL) (Tool 15 = CENTERDRILL) N1 T15 M06 M08 M03 S3000 G00 Z1.1 G43 H15 N2 G81 X3.9077 Y-0.331 Z-0.1 R0.1 F12. N3 X7.1077 N4 X10.3077 N5 X13.5077 N6 X16.7077 G80 N7 G00 Z0.1 N1 T30 M06 M08 M03 S5000 G00 Z1.1 G43 H30 N2 G83 Q0.1 X3.9077 Y-0.331 Z-1.1 R0.1 F18. N3 X7.1077 N4 X10.3077 N5 X13.5077 N6 X16.7077 G80 N7 G00 Z0.1 |
| Hi panaceabea Your Gcode format is not very good I think also your tools may be not set right is the 1.1 above the part for some reasion Each tool should be touched off the top of the part I have attched a txt file that you can run make sure the numbers are the same as yours you may need to remove the G98 as this will make your retracts go to 1.1 instead of R.1 Also you may need to move the G57 to above the S3000M3 & S5000M3 some controls don't like were it is
__________________ Mactec54 |
| This is a new Haas? It will have proximity sensors not mechanical switches. I don't think we have ever missed a tool change and had the program continue to run but we have sometimes had the toolchanger get lost and trigger an alarm because a chip landed on one the the proximity sensors that detect the position of the carousel. The big problem is finding the culprit chip still in place so you can wipe it off and have the problem go away to more or less prove that was the cause. I think this is going to be one of those glitches that you have to grit your teeth about and cross your fingers as you press the green button. Maybe Murphy is now satisfied and it will never happen again.
| Wow, I've never seen (in 12 or 13 years of daily use) a Haas skip a tool change...but I've also never seen anyone re-use the same line numbers in a program. I'm going to guess that the duplicate line numbers confused the Hass's Block Lookahead somehow. |
Not likely. The Haas controller only takes notice of the line numbers when you do a subroutine or line jump. The local subroutine call M97 P22 for instance looks for the first line numbered N22 and goes to that. You can have many lines labelled N22 but it goes to the first and ignores all the rest. The jump command M99 P22 will jump to the first N22 it finds.
It's 2 AM... why am I on here?? Addicted, I guess. |
| Yes its a 2009 The tools are set correctly ,the 1.1 inch above the part is a point it can rapid to and be clear of clamps, the duplicate line numbers are just a result of piecing together multiple strings of code manualy (cut and paste) in a text editor and not taking the time to delete the line numbers. I have never payed attention to line numbers , never had an issue before that resulted from random N** sequence. The program the above block is part of has run thousands of times with no problem on two other machines and at least 165 times on the new haas over the past few days. It had run 9 other times earlier in the day with no problems. There were three tool changes and operations that ran before the change to T15 and then the missed tool change. This same program with the same tools, no changes had run at least 165 times over the past few days with no problem . I cant figure how it could be a prox sensor in the tool changer unless it were just after start up and this problem occured after 9+ hours of running the same program. The machine had cycled thru at least 50 or so tool changes at this point in the day. I will just sit with the machine the next few weeks and make sure it goes thru all the tool changes before leaving it un-attended again in hope Murphy doesnt return |
| If you are gonna sit and babysit, you can set up M00 after each tool change so if infact it does go wonky, it wont crash into your part. It will suck if you have a alot of tool changes in a relatively short period though since you will have to push the start button to advance each time. |
The machine didn't skip only tool change, but al the comands between N1 and N2, because if it has processed G143 H30 no damage would occur. So, it's very hard to accept this situation, but if you are TOTALLY sure that no one has touched the machine while it was running, look after the machine during the first days of operation, after fixed, and imediately turn the setting 36 - Program Restart to ON (the default factory condition is OFF). I'm pretty sure that if it was turned ON before, this damage wouldn't occur. Keep in touch about this issue, I bet we all want to know about a happy ending for your history. |
#10
| G43 ( take up tool length ) usually forces rapid, but with a G00 at the front may cause the machine to ignore the length comp , and give the appearance that it missed a toolchange. Query your manuals if these 2 can be on the same line ??? I would write it as to be safe Code: (MOVE BACK TO TOP TO DRILL) (Tool 15 = CENTERDRILL) N1 T15 M06 X3.9077 Y-0.331 M03 S3000 G43 H15 Z1.1 M08 G99 G81 X3.9077 Y-0.331 Z-0.1 R0.1 F12. (G99 = return to the Z1.1 after each hole) X7.1077 X10.3077 X13.5077 X16.7077 G80 G0 Z1.1 |
#12
| Hi panaceabea I agree with Caue that if everything was set up correct as you have said even if it did miss a toolchange it still would not crash your tool holder into your work & damage your fixture so something else happened to do this the worst it could do is break the drill & keep going
| Problem- tool change in DNC mode with fanuc OM controller-KIWA Excel 510 machine | flaheu | General Metalwork Discussion | 4 | 09-08-2008 09:50 AM |
| Machine hang during tool change | javajesus | Sharp CNC | 44 | 01-19-2008 10:27 PM |
| Very slow tool change on Tool Room Mill | Capt Crunch | Haas Mills | 3 | 12-21-2007 12:20 PM |
| Drilling operation - 1st hole always skipped? | JMFabrications | Mastercam | 6 | 07-15-2007 06:02 PM |
| How to change Tool change position(About MAZATROL T1 control) | liushuixingyun | Mazak, Mitsubishi, Mazatrol | 5 | 07-07-2007 02:58 PM |
