Old 04-16-2009, 12:42 PM
panaceabea is on a distinguished road
g47 font spacing ?
I am having a problem with the spacing of a couple of characters having odd spacing when engraving text with g47 . All the letters and numbers come out perfectly but when I engrave R&D on one of my customers parts it comes out as R &D with a full space between the R and & even though no space exist in the text written between the () .
If I change the text in the parenthisis to read (R& D) with a space between the & and D in hopes of at least having eqaul spacing on either side of the & symbol it then engraves the & right up against the R
I have a coule of hundred parts that are being rejected by the customer and I need to know how to rectify before I engrave the other 2k + parts
Old 04-16-2009, 02:18 PM
JWK42 is on a distinguished road
Can you use 3 different lines of code set the spacing with your X start position?
G47 P0 X0. Y0. J.5 R.05 Z-.02 F10. E5. (R)
G47 P0 X.375 Y0 J.5 R.05 Z-.02 F10. E5. (&)
G47 P0 X.75 Y0 J.5 R.05 Z-.02 F10. E5. (D)
Or (R + 3 spaces + D) and then center the ampersand on them.
Old 04-16-2009, 02:28 PM
now thats a pretty good idea , i will mount a vice at one end of the table past my fixture and experimint with it and see what the x coordinates need to be to get the & centered up .
I am/was hoping there was a simpler fix so I dont have to go thru the trial and error of dialing it in
Old 04-16-2009, 03:07 PM
rshields21 is on a distinguished road
If you give me your g47 line I can post a mastercam program for it.
Otherwise doing the xy for each character is the only solution I can think of.
Old 04-16-2009, 03:19 PM
Thanks, I just generated the file in master cam and am headed out to give it a test run
Old 04-22-2009, 05:10 PM
Ginger_Ninja54's Avatar
Ginger_Ninja54 is on a distinguished road
When I'm creating a new engraving program, i always program a M97 P1000 and create a 'N1000' sub at the end and call it just before the g47, before any Z depths.
The sub will be positions of reference, holes or outside edges/form of the part.
Then when you run graphics you can get a better representation of what you are going to get.
Just remove or block delete the M97 line to run the cycle.
>>>>>>>>>> Made In England <<<<<<<<<<
air hole spacing? ckrantz Vacuum forming, Thermoforming Etc 1 11-16-2008 11:43 PM
Just IN- Large font small font CNCadmin CNCzone Site News and Contests 0 10-26-2008 12:47 AM
Help with equal spacing MegaMoog EdgeCam 0 06-03-2007 08:45 AM
Mastercam True Type font spacing? larrynsr Mastercam 2 12-08-2006 08:48 PM
Bolt spacing on THK rail? samualt DIY-CNC Router Table Machines 6 07-24-2004 06:36 PM
