Old 04-09-2009, 12:41 PM
panaceabea is on a distinguished road
G47 MACRO 599 QUESTION
I have a few thousand parts I need to serial number during one of my setups and the need to be seq numbered . I am playing with the g47 sub and it seems great . The manual mentions I can define the begining of a serial number range by entering the # in macro 599 and to see the section on macros for more info. I cant seem to figure this out , could someone give me a quick how to on entering the starting number in macro 599?
I also have a customer that wants different batches of parts to start with a letter , ie A B C etc , then followed with the 4 digit number sequence, when I am writing the line to generate the seq serial numbers can it be written as G47 P1 (A####) . If so will it generate text of A1234, A1235, A1236 etc?
Or does the A need to be written in a seperate line G47 P0 (A) then second line G47 P1 (####) with each line having the proper XY coordinates?
Thanks Rich
Old 04-09-2009, 12:48 PM
Originally Posted by panaceabea View Post
....Or does the A need to be written in a seperate line G47 P0 (A) then second line G47 P1 (####) with each line having the proper XY coordinates?
Thanks Rich
Yes.
One G47 does your text another G47 does the sequential number starting at whatever you enter in 599.
Old 04-09-2009, 01:05 PM
how do I enter the number in 599
Old 04-09-2009, 01:27 PM
CRNT CMDS and page down until you find the Macro Variables page.
Type 599 and press Write.
Type your starting number and press Write.
Old 04-09-2009, 03:00 PM
CRNT CMMDS
599 down arrow
Old 04-09-2009, 03:38 PM
CRNT CMMDS
599 down arrow
Correct, I remember now that you mention it.
If your customer wants truly sequential numbers you need to take a bit of care because the counter increments even during Graphics I think; any time the program hits and M30.
Old 04-09-2009, 04:27 PM
well I have run the first batch of parts and the format G47 P1 (A####) does indeed work and machines the serial starting with th A and then the string of 4 number
custom macro question sinha_nsit G-Code Programing 28 04-18-2009 06:44 AM
macro question loop modulus G-Code Programing 13 03-24-2009 02:27 PM
Macro B Question Bluetech Fanuc 7 03-10-2009 12:58 AM
21i Macro Question marcwdci Fanuc 3 03-11-2008 02:04 PM
